#1 16.05.2012 12:33
Postovi:1,830
Predmet:Queries to VBA
Imam edno Queri od koe imam izvadeno raport sega mi treba nesto slicno da go napravam za pecatejne preku VBA no ne mozam da go izvedam.
Eve go cql od od Querito
  1. SELECT tblSmetki_Stavki.Stavka, Sum(tblSmetki_Stavki.Kolicina) AS Kolicina, tblSmetki_Stavki.Procent, tblSmetki_Stavki.Ed_Cena
  2. FROM tblSmetki INNER JOIN tblSmetki_Stavki ON tblSmetki.ID_Smetka = tblSmetki_Stavki.Smetka_Br
  3. WHERE (((tblSmetki.Data) Between [Forms]![frmPregled_Kasa_Restoran]![txtDataOD] And [Forms]![frmPregled_Kasa_Restoran]![txtDataDO]) AND ((tblSmetki.Magacin)=[Forms]![frmPregled_Kasa_Restoran]![cboMagacin]))
  4. GROUP BY tblSmetki_Stavki.Stavka, tblSmetki_Stavki.Procent, tblSmetki_Stavki.Ed_Cena
  5. ORDER BY Sum(tblSmetki_Stavki.Kolicina) DESC;
Eve kako go vadam recordsetot vo VBA
  1. Dim db As DAO.Database
  2. Dim rs As DAO.Recordset
  3. Set db = CurrentDb()
  4. Set rs = db.OpenRecordset("qryKasa_Artikli_Top")
  5. While Not rs.EOF
  6.   MsgBox rs.Fields(1)
  7.   rs.MoveNext
  8. Wend
  9. Set rs = Nothing
#2 16.05.2012 13:11
Predmet:Re: Queries to VBA
Koji je tip polja ovo:
txtDataDO i txtDataOD
i
cboMagacin]
#3 16.05.2012 13:42
Postovi:1,830
Toa se polijna od formata za kade sto ke se stampa eve ke stavam i primer
Informacije o tipu datoteke za:rar  Primer.rar
Preuzimanja:360
Velicina datoteke:119.31 KB
#4 16.05.2012 14:25
  1. Function QueryP()
  2. Dim Db As Database
  3. Dim Rs As Recordset
  4. Dim SQL As String
  5. Dim Datum(1 To 2) As String
  6. Dim Magacin As Integer
  9. Set Db = CurrentDb()
  10. Magacin = Forms![frmPregled_Kasa_Restoran]![cboMagacin]
  11. Datum(1) = [Forms]![frmPregled_Kasa_Restoran]![txtDataOD]
  12. Datum(1) = DatumSQL(Datum(1))
  13. Datum(2) = [Forms]![frmPregled_Kasa_Restoran]![txtDataDO]
  14. Datum(2) = DatumSQL(Datum(2))
  15. SQL = "SELECT Stavka, Sum(Kolicina) AS Suma, Procent,Ed_Cena " _
  16.     & "FROM tblSmetki " _
  17.     & "INNER JOIN tblSmetki_Stavki ON tblSmetki.ID_Smetka = tblSmetki_Stavki.Smetka_Br " _
  18.     & "WHERE Data Between " & Datum(1) & " AND " & Datum(2) & "AND Magacin=" & Magacin _
  19.     & " GROUP BY Stavka, Procent, Ed_Cena " _
  20.     & "ORDER BY Sum(Kolicina) DESC;"
  21. Set Rs = Db.OpenRecordset(SQL)
  22. While Not Rs.EOF
  23.   MsgBox Rs.Fields(1)
  24.   Rs.MoveNext
  25. Wend
  26. End Function
  27.
  28.
  29. Function DatumSQL(Datum As String)
  30. Dim DatumS As String
  31.
  32. DatumS = Format(Datum, "mm-dd-yyyy hh:nn:ss")
  33. DatumSQL = "#" & DatumS & "#"
  34. End Function
#5 16.05.2012 14:58
Postovi:1,830
ova funkcionira fala zxz pozdrav
#6 16.05.2012 21:53
Bosanec Van mreze
Postovi:155
evo jedan adin za pretvorbu kverija u vba
alat je izuzetno dobar ne treba razbijat glavu Happy
pozdrav
Informacije o tipu datoteke za:rar  SQL Grabber.rar
Preuzimanja:385
Velicina datoteke:18.42 KB
#7 16.05.2012 22:42
Bosanec to postavi u ovu temu.
http://www.icentar.ba/showtopic.php?id=37
Sva vremena su GMT +02:00. Trenutno vrijeme: 2: 10 pm.
