#121 06.06.2015 13:05
Postovi:1,830
Jas kaj mene imam konctanti DA i NE koi na start na program se odreduvaat vo zavisnost od tipot na konekcijata sto ke bidat.
Ako e MsAccess DA=True
ako e MsSql DA=1
ako e MySql DA=-1
#122 08.06.2015 11:37
ne znam postoji li neka funkcija za konekciju na my sql ovog tipa:
  1. Private Sub LinkDizIS_Click()
  2.     Dim Baza As Database
  3.     Dim tdfLinked As TableDef
  4.     Dim i As Integer
  5.     Dim a As Integer
  6.     Dim IME As String
  8.     Set Baza = CodeDb
  11.     Me.NazivServera = Me.LokalNazivServera
  12.     Me.NazivBaze = Me.LokalNazivBaze
  13.     Me.Korisnik = Me.LokalKorisnik
  14.     Me.Lozinka = Me.LokalLozinka
  15.     Me.Requery
  16.
  17.     DoCmd.OpenForm "Cekaj"
  18.     DoCmd.RepaintObject A_FORM, "Cekaj"
  19.
  20.     DoCmd.SetWarnings False
  21.
  22.     On Error Resume Next
  23.     With Baza
  24.     a = .TableDefs.Count - 1
  25.         For i = a To 0 Step -1
  26.             IME = .TableDefs(i).Name
  27.             If .TableDefs(i).Connect <> "" Then
  28.                     .TableDefs.Delete IME
  29.             End If
  30.         Next i
  31.     End With
  32.
  33.     Dim Tabele As DAO.Recordset
  34.     Dim ImeTabele As String
  35.     Dim KonektString As String
  36.     'Provider=sqloledb;Data Source=190.190.200.100,1433;Network Library=DBMSSOCN;Initial Catalog=pubs;User ID=myUsername;Password=myPassword;
  37.     'KonektString = "Provider=sqloledb" & ";ODBC;DRIVER=SQL Server;SERVER =" & "192.168.1.33,1433" & ";Network Library=DBMSSOCN;Initial Catalog=" & Me.LokalNazivBaze & ";User ID=" & Me.LokalKorisnik & ";Password=" & Me.LokalLozinka & "'" ';Trusted_Connection"
  38.     KonektString = "ODBC;DRIVER=SQL Server;SERVER=" & Me.LokalNazivServera & ";UID=" & Me.LokalKorisnik & ";PWD=" & Me.LokalLozinka & ";DATABASE=" & Me.LokalNazivBaze & ";Trusted_Connection"
  39.     'KonektString = "ODBC;DRIVER=SQL Server;SERVER=" & "192.168.1.33,1433" & ";UID=" & Me.LokalKorisnik & ";PWD=" & Me.LokalLozinka & ";DATABASE=" & Me.LokalNazivBaze & ";Trusted_Connection"
  40.     SendKeys ("{ENTER}")
  41.
  42.     DoCmd.TransferDatabase acLink, "ODBC Database", KonektString, acTable, "sysobjects", "LinkTables", , True
  43.
  44.     Set Baza = CurrentDb
  45.     Set Tabele = Baza.OpenRecordset("QLinkTables1") ', DB_OPEN_DYNASET)
  46.
  47.    With Tabele
  48.       Do While Not .EOF
  49.             ImeTabele = Tabele("Name")
  50.             If Trim(Tabele("type")) = "V" Then
  51.
  52.                 DoCmd.TransferDatabase acLink, "ODBC Database", KonektString, acTable, ImeTabele, ImeTabele, False, True
  53.
  54.             Else
  55.                 DoCmd.TransferDatabase acLink, "ODBC Database", KonektString, acTable, ImeTabele, ImeTabele, False, True
  56.
  57.             End If
  58.             .MoveNext
  59.       Loop
  60.    End With
  61.
  62. '    Set Baza = CodeDb
  63.
  64. '    With Baza
  65. '        .TableDefs.Delete "LinkTables"
  66. '    End With
  67.
  68.     DoCmd.Close A_FORM, "Cekaj"
  69.     BEEP
  70.
  71.     DoCmd.SetWarnings True
  72.     DoCmd.Close acForm, "_Link"
  73.
  74. End Sub
#123 08.06.2015 12:13
Postovi:1,830
Samo zameni go KonektString i napravi go za MYSQL ovaj isti kod bo trebalo da funkcionira
#124 08.06.2015 12:46
Probao sam ovako stavit:
KonektString = "ODBC;DRIVER=MySql ODBC 5.3 Driver Server;SERVER=" & Me.LokalNazivServera & ";UID=" & Me.LokalKorisnik & ";PWD=" & Me.LokalLozinka & ";DATABASE=" & Me.LokalNazivBaze & ";Trusted_Connection"
I ovako:
  1. KonektString = "Driver={Mysql ODBC 5.1 Driver}; Server=" & "127.0.0.1" & _
  2.                            ";port=3306; database=" & "FiskalBaza" & _
  3.                            "; user=" & "root" & _
  4.                            "; password=" & "1283" & "; option=3;"
Ali ne radi. Ne javlja nikakvu grešku
Ovaj post je ureden 1 puta. Posljednja izmjena 08.06.2015 12:48 od strane miro35. ↑  ↓
#125 08.06.2015 13:08
Postovi:1,830
Ova e ADO treba da vidis kako e za DAO kolku sto gledam ti DAO koristis
#126 08.06.2015 13:08
kenan Van mreze
Registrovan od:10.02.2011
Postovi:191
evo ti string
kod servra koristiÅ¡ za lokalno povezivanje "localhost" a za sa nekog računara najsigurnije je ip adresa računara na kojem je postavljena baza normalno u lokalnoj mrezi ili vpn mrezi a za preko neta malo komplikovanije
strConnect = "ODBC;DRIVER={Mysql ODBC 5.1 Driver}" _
& "; port=3306;" _
& "; SERVER=" & strServer _
& "; DATABASE=" & strDatabase _
& "; user=" & strUID _
& "; password=" & strPWD _
& "; option=3;"
#127 08.06.2015 13:14
Postovi:1,830
Dali go istalira odbc Drajverot?
#128 08.06.2015 13:24
jesam instalirao sam i kreirao sam ga. Mogu preko njega da se povežem u access-u preko link table pa onda odbc driver.I tako mogu da biram tabele sve radi.Ali želim da napravim preko vba. Ako imate vi neku funkciju koja radi postavite.Želio bih da bude tako da imam neki spisak tabela i da te tabele linkuje.Isto tako da briše link pa da osvježavam novi link.tako nekako
#129 08.06.2015 13:32
kenan Van mreze
Postovi:191
sad ču ti poslati da skrpim
#130 08.06.2015 14:08
kenan Van mreze
Postovi:191
evo ti sve Å¡to ti je potrebno čak možeÅ¡ raditi neprestanu promjenu vrste servera sa sql na Mysql ali to čeÅ¡ sam skontati. Također ako kod ms sql koristi trustedkonekciju imaÅ¡ i to
uglavnom u tabeli serever napuniš podatcima prema svojim postavkama
a u tabelu drugu tabelu napiÅ¡eÅ¡ naziv tabele onako kako si je nazvao na serveru kod mysql je to jednostavno isto se preslikava ali kod ms sql vidjet ćeÅ¡ dodatak "dbo." i nediraj jer tako se zapisu je u strukturnu tabelu ali ako hočeÅ¡ da ti se koristi u nazivu dodatak "dbo_" to promjeniÅ¡ ako se dobro sječam Set tdfAccess = dbs.CreateTableDef("dbo_" & rs![LinkTablename], dbAttachSavePWD) ovdje ali preporučujem da puno se neigraÅ¡ sa ovim
Informacije o tipu datoteke za:rar  sql i mysql konekcija.rar
Preuzimanja:203
Velicina datoteke:47.76 KB
Stranice (16):1,2 ... 11,12,13,14,15,16
Sva vremena su GMT +02:00. Trenutno vrijeme: 4: 29 pm.
