#11 26.05.2016 15:02
nevsad Van mreze
Registrovan od:01.09.2010
Postovi:231
Predmet:Re: Problem Petlja
dobar rezon ali dobijes isto sto i ja na pocetku
pokusaj iz formr nefiskalni
samo ukloni ono o misu
pozdrav
#12 26.05.2016 15:02
Sad vidim da si ti to i pokusao rijesiti kodom.
  1. Public Function taxaOddo()
  2. Dim rst As DAO.Recordset
  3. IzborPrintera
  4. br = 1
  5. izn = 0
  6. siznos = 0
  7. Suma = 0
  8. Close #1
  9. Set rst = CurrentDb.OpenRecordset("KORISNIK")
  10. 'Open rst!Port For Output As #1
  11. Open "C:\Temp\taxa.txt" For Output As #1
  12. Print #1, strParPrint
  13. Print #1, strIzbTrake
  14. Print #1, strObSlova
  15. Print #1, Tab(21 - Len(rst!korisnik)); rst!korisnik
  16. Print #1, Tab(21 - Len(rst!adresa) - Len(rst!grad)); Nz(rst!adresa, ""); ","; Nz(rst!grad)
  17. Print #1, "Izvjestaj o prodatim artiklima za period"
  18. Print #1, Tab(7); "od"; Tab(10); Format(Pocetni, "dd.mm.yyyy"); Tab(22); "do"; Tab(25); Format(Krajnji, "dd.mm.yyyy")
  19. Print #1, "========================================"
  20. Print #1, "    Datum                         Taxa                       Iznos"
  21. Print #1, "========================================"
  22. rst.Close
  23. Set rst = CurrentDb.OpenRecordset("select * from Qzaperiod1  WHERE datum BETWEEN DATEVALUE('" & Pocetni & "') AND DATEVALUE('" & Krajnji & "')")
  24. rst.MoveFirst
  25. Datum = rst!Datum
  26. Do Until rst.EOF
  27.    sif = rst!proizvod
  28.    im = rst!ime
  29.    izn = rst!SumOfiznos
  30.  If Datum <> rst!Datum Then
  31.  Print #1, "----------------------------------------"
  32.  Print #1, Datum; Tab(41 - Len(Format(siznos, "###0.00"))); Format(siznos, "###0.00")
  33.  Print #1, "----------------------------------------"
  34.  siznos = 0
  35.  Datum = rst!Datum
  36.  End If
  37.         Print #1, Format(rst!Datum, "dd.mm.yyyy"); "  "; sif; Tab(16); right(im, 24); Tab(41 - Len(Format(izn, "###0.00"))); Format(izn, "###0.00")
  38. siznos = siznos + rst!SumOfiznos
  39. rst.MoveNext
  40. Loop
  41.
  42. Set rst = CurrentDb.OpenRecordset("select * from Qzaperiod2  WHERE datum BETWEEN DATEVALUE('" & Pocetni & "') AND DATEVALUE('" & Krajnji & "')")
  43. izn = 0
  44. Suma = 0
  45. rst.MoveFirst
  46. Datum = rst!Datum
  47. Print #1, "----------------------------------------"
  48. rst.MoveFirst
  49. Do Until rst.EOF
  50.    Suma = Suma + rst!SumOfiznos
  51.    rst.MoveNext
  52. Loop
  53. rst.MoveFirst
  54.       Print #1, "SVEUKUPNO :            "; Tab(41 - Len(Format(Suma, "####0.00"))); Format(Suma, "####0.00"); " KM"
  55.       Print #1, "----------------------------------------"
  56. Print #1, Chr(27) & Chr(100) & Chr(8)
  57. Print #1, Chr(27) & Chr(105)
  58. Close #1
  59.  End Function
#13 26.05.2016 15:10
nevsad Van mreze
Postovi:231
tako blizu a tako daleko
fino hvala
nevsad
#14 28.05.2016 11:33
Mozes i sumu izracunati u petlji pa ti netreba ovaj rst Qzaperiod2
Bit ce jos brze i efikasnije.
U if uslovu sabiras sumu prije
siznos = 0
#15 30.05.2016 09:33
nevsad Van mreze
Postovi:231
probat cu ali tu imam jos jedan uvjet
filter je tarifni broj 4 za rst Qzaperiod2
a za rst Qzaperiod1 je tarifni broj 2
sto znaci da rst Qzaperiod1 kao uvjet moram ulkjuciti itarifni broj
priznam da sam isao linijom manjeg otpora
probam pa se cujemo
pozdrav
nevsad ramic
#16 30.05.2016 09:46
nevsad Van mreze
Postovi:231
greska sve je tarifa 4 ne treba nikakav dodatni uvjet
probao za period 1.5.2016-23.52016 i ok jeali nema sume zadnjeg recordaza dan umjesto
toga je suma ukupna
nevsad ramic
#17 30.05.2016 10:03
nevsad Van mreze
Postovi:231
IzborPrintera
br = 1
izn = 0
siznos = 0
Suma = 0
Close #1
Print #1, Tab(7); "od"; Tab(10); Format(pocetni, "dd.mm.yyyy"); Tab(22); "do"; Tab(25); Format(krajnji, "dd.mm.yyyy")
rst.Close
Set rst = CurrentDb.OpenRecordset("select * from Qzaperiod1 WHERE datum BETWEEN DATEVALUE('" & pocetni & "') AND DATEVALUE('" & krajnji & "')")
rst.MoveFirst
Datum = rst!Datum
Do Until rst.EOF
sif = rst!proizvod
im = rst!ime
Suma = rst!SumOfiznos
siznos = 0
Datum = rst!Datum
rst.MoveNext
Loop
rst.MoveFirst
Do Until rst.EOF
rst.MoveNext
Loop
rst.MoveFirst
Close #1
treba biti 273
ja dobijem uvecan za zadnju sumu koju mi nesabere(da se vidi)
pozdrav nevsad
#18 30.05.2016 11:12
Postovi:4,710
ja sam mozda krivo razumio , neznam
siznos = 0
znaci, onako kako sam ja razumio umjesto ovoga:
  1. If Datum <> rst!Datum Then
  2.         Print #1, "----------------------------------------"
  3.         Print #1, Datum; Tab(41 - Len(Format(siznos, "###0.00"))); Format(siznos, "###0.00")
  4.         Print #1, "----------------------------------------"
  5.         siznos = 0
  7. End If
staviti ovo:
  5.         Suma = Suma + rst!SumOfiznos
  6.         siznos = 0
  7.         Datum = rst!Datum
  8. End If
a kod tebe je zbrajanje u do loop petlji
  5.         Suma = rst!SumOfiznos
  6.         siznos = 0
  8. End If
  10. Do Until rst.EOF
  11.         Suma = Suma + rst!SumOfiznos
  12.         rst.MoveNext
  13. Loop
#19 30.05.2016 12:35
nevsad Van mreze
Postovi:231
Datum Taxa Iznos
16.05.2016 56 RadnaTaksa 7.00
16.05.2016 56e rad.txt e_recept 40.00
16.05.2016 47.00
17.05.2016 56e rad.txt e_recept 34.00
17.05.2016 34.00
18.05.2016 56 RadnaTaksa 9.00
18.05.2016 56e rad.txt e_recept 38.00
18.05.2016 47.00
19.05.2016 56 RadnaTaksa 6.00
19.05.2016 56e rad.txt e_recept 59.00
19.05.2016 65.00
20.05.2016 56 RadnaTaksa 23.00
20.05.2016 56e rad.txt e_recept 21.00
20.05.2016 44.00
21.05.2016 55 participacija 1.00
21.05.2016 56e rad.txt e_recept 5.00
21.05.2016 6.00
23.05.2016 56e rad.txt e_recept 30.00
SVEUKUPNO : 273.00 KM
ovo sam rijesio ali generalno ostaje problem sume zadnjeg dana
23.05.2016 ne zbroji
niti rst.MoveLast ne odigra utakmicu
pozdrav nevsad
#20 30.05.2016 12:57
nevsad Van mreze
Postovi:231
ovo da rezultat
Suma = 0
siznos = 0
Datum = rst!Datum
rst.MoveNext
Loop
rst.MoveFirst
Do Until rst.EOF
rst.MoveNext
Loop
rst.MoveFirst
Close #1
nemam ideje
nevsad
Sva vremena su GMT +02:00. Trenutno vrijeme: 1: 05 pm.
