#1 04.08.2017 10:31
Postovi:4,710
Predmet:direktorij ucitavanja je direktorij excel fajla
  1. Sub proba()
  2.     Dim wsCopy As Worksheet
  3.     Dim rngCopy As Range
  4.     Dim wbPaste As Workbook
  5.     Dim wsPaste As Worksheet
  6.     Dim rngPaste As Range
  8.     aktivniList = ActiveSheet.Name
  10.     ChDir ActiveWorkbook.Path 'odredivanje direktorija u kojem se nalazi excel datoteka sa procedurom
  12.     FileToOpen = Application.GetOpenFilename _
  13.                 (Title:="izaberi datoteku za uvoz podataka", _
  14.                 FileFilter:="prihvacene extenzije *.xls (*.xlsm),")
  16.     If FileToOpen = False Then
  17.         'ako datoteka nije izabrana
  18.         MsgBox "Nije izabrana datoteka.", vbExclamation, "ERROR"
  19.         Exit Sub
  20.     Else
  21.         'ako je datoteka izabrana
  22.
  23.         imeFajla = GetFilenameFromPath(FileToOpen) 'ime datoteke koju smo uzeli
  24.
  25.         Set wbPaste = ActiveWorkbook
  26.         Set wbCopy = Workbooks.Open(FileToOpen)
  27.         Set wsCopy = wbCopy.Worksheets("Sheet1")
  28.
  29.         zadnjiRed = traziZadnjiRed("Sheet1", 1)
  30.         zadnjaKolona = traziZadnjuKolonu("Sheet1")
  31.
  32.         Set rngCopy = wsCopy.Range(Cells(1, 1), Cells(zadnjiRed, zadnjaKolona))
  33.         Set wsPaste = wbPaste.Worksheets(aktivniList)  'shit u koji idu podaci
  34.         Set rngPaste = wsPaste.Range("A1")  'pocinje od celije A1
  35.
  36.         rngCopy.Copy
  37.         rngPaste.PasteSpecial
  38.
  39.         Workbooks.Application.CutCopyMode = False
  40.
  41.         Filename = ActiveWorkbook.Name
  42.         Workbooks(Filename).Close
  43.     End If
  44. End Sub
  45.
  46. Function traziZadnjiRed(ImeSita As String, kolona)
  47.     Dim Zadnji As Long
  48.     Dim ws As Worksheet
  49.
  50.     Set ws = Sheets(ImeSita)
  51.     With ws
  52.         Zadnji = .Cells(.Rows.Count, kolona).End(xlUp).Row
  53.     End With
  54.     traziZadnjiRed = Zadnji
  55. End Function
  56.
  57. Function traziZadnjuKolonu(ImeSita As String)
  58.     Dim Zadnji As Long
  59.     Dim ws As Worksheet
  60.     Dim zadnjaCelija As Range
  61.
  62.     Set ws = Sheets(ImeSita)
  63.
  64.     Set zadnjaCelija = ws.Cells.Find(What:="*", After:=ws.Cells(1, 1), LookIn:=xlFormulas, _
  65.                                     LookAt:=xlPart, SearchOrder:=xlByColumns, _
  66.                                     SearchDirection:=xlPrevious, MatchCase:=False)
  67.
  68.     Zadnji = zadnjaCelija.Column
  69.     traziZadnjuKolonu = Zadnji
  70. End Function
  71.
  72. Function GetFilenameFromPath(ByVal strPath As String) As String
  73.     ' npr. 'c:\winnt\win.ini' vraca 'win.ini'
  74.
  75.     If Right$(strPath, 1) <> "\" And Len(strPath) > 0 Then
  76.         GetFilenameFromPath = GetFilenameFromPath(Left$(strPath, Len(strPath) - 1)) + Right$(strPath, 1)
  77.     End If
  78. End Function
sa ovom gore procedurom kopiram shit iz neke excel datoteke u otvorenu excel datoteku. Problem je u tome kada dode do getFileOpen ponudi mi direktorij u kojem se ne nalazi ova datoteka pa moram rucno doci do fajla kojeg zelim ucitati. Fajl koji zelim ucitati nalazi se u istom folderu gdje se nalazi i ovaj fajl iz kojeg radi ova procedura.
Pitanje: kako postaviti putanju za ucitavanje onu u kojoj se nalazi i excel fajl, tj. ova procedura.
Ovaj post je ureden 1 puta. Posljednja izmjena 04.08.2017 10:39 od strane Avko. ↑  ↓
#2 04.08.2017 16:12
Postovi:625
Predmet:Re: direktorij ucitavanja je direktorij excel fajla
Umesto
stavi
Application.DefaultFilePath = Application.ThisWorkbook.Path
#3 08.08.2017 08:02
Postovi:4,710
Hvala dex to je to
Sva vremena su GMT +02:00. Trenutno vrijeme: 7: 34 am.
