#1 08.03.2018 12:53
xl_kid Van mreze
Registrovan od:11.11.2008
Postovi:154
Predmet:Enter kao tab u DataGridView kako?
Pomoć prijatelja Smiling
kako da u DataGridView-u nateram ENTER da radi kao TAB. Dole je kod sa forme
podešavanja
EditMode: EditOnEnter
cod
Public Class Form1
Private Sub PorudzbineBindingNavigatorSaveItem_Click(sender As Object, e As EventArgs) Handles PorudzbineBindingNavigatorSaveItem.Click
Try
Me.Validate()
Me.PorudzbineBindingSource.EndEdit()
Me.TableAdapterManager.UpdateAll(Me.Porudzbine_DataSet)
Me.PorudzbineDetaljiTableAdapter.Update(Me.Porudzbine_DataSet)
Catch ex As Exception
MessageBox.Show(ex.ToString)
End Try
Private Sub Form1_KeyDown(sender As Object, e As KeyEventArgs) Handles Me.KeyDown
If e.KeyCode = Keys.Enter Then
Me.SelectNextControl(Me.ActiveControl, True, True, True, False) 'for Select Next Control
Private Sub Form1_Load(sender As Object, e As EventArgs) Handles MyBase.Load
'TODO: This line of code loads data into the 'Porudzbine_DataSet.PorudzbineDetalji' table. You can move, or remove it, as needed.
Me.PorudzbineDetaljiTableAdapter.Fill(Me.Porudzbine_DataSet.PorudzbineDetalji)
'TODO: This line of code loads data into the 'Porudzbine_DataSet.Relacije' table. You can move, or remove it, as needed.
Me.RelacijeTableAdapter.Fill(Me.Porudzbine_DataSet.Relacije)
'TODO: This line of code loads data into the 'Porudzbine_DataSet.Kupci' table. You can move, or remove it, as needed.
Me.KupciTableAdapter.Fill(Me.Porudzbine_DataSet.Kupci)
'TODO: This line of code loads data into the 'Porudzbine_DataSet.Porudzbine' table. You can move, or remove it, as needed.
Me.PorudzbineTableAdapter.Fill(Me.Porudzbine_DataSet.Porudzbine)
Private Sub NazivComboBox_LostFocus(sender As Object, e As EventArgs) Handles NazivComboBox.LostFocus
Dim id_dm As New Porudzbine_DataSetTableAdapters.KupciTableAdapter
Try
KupacIDTextBox.Text = id_dm.id_dm_ScalarQuery(NazivComboBox.Text)
End Try
Private Sub PorudzbineDetaljiDataGridView_CellEndEdit(sender As Object, e As DataGridViewCellEventArgs) Handles PorudzbineDetaljiDataGridView.CellEndEdit
Dim naziv_proizvoda As New Porudzbine_DataSetTableAdapters.ProizvodiTableAdapter
If e.ColumnIndex = 0 Then
If Val(PorudzbineDetaljiDataGridView.Rows(e.RowIndex).Cells(e.ColumnIndex).Value) > 0 Then
PorudzbineDetaljiDataGridView.Rows(e.RowIndex).Cells(e.ColumnIndex + 1).Value = naziv_proizvoda.NazivProizvoda_ScalarQuery(CInt(Val(PorudzbineDeta
ljiDataGridView.Rows(e.RowIndex).Cells(e.ColumnIndex).Value)))
End Class
#2 08.03.2018 15:26
Postovi:1,830
Predmet:Re: Enter kao tab u DataGridView kako?
Eve ti cod za ovaj problem :
na onKey_Down stavi go ova
  1. If KeyCode = vbKeyReturn Then
  2.      SendKeys "{TAB}"
  3.      'CreateObject("WScript.Shell").SendKeys "{TAB}", True
  4.  End If
Ova e za VB6 i VBA
Eve za vb Net
  1.  If e.KeyChar = Microsoft.VisualBasic.ChrW(Keys.Return) Then
  2.         SendKeys.Send("{TAB}")
  3.         e.Handled = True
  4.     End If
Ovaj post je ureden 1 puta. Posljednja izmjena 08.03.2018 15:29 od strane Gjoreski. ↑  ↓
#3 08.03.2018 15:56
xl_kid Van mreze
Postovi:154
Neće. NeÅ¡to ne Å¡tima. I dalje posle unosa ili pregleda na prvo polje ide red ispod i tako dalje.
#4 08.03.2018 18:13
Postovi:1,830
gde si stavio funkcija?
Proveri dali na onKey_Down nastan kad udaris enter nesto se dogadza na primer stavi msgbox
  2.         'SendKeys.Send("{TAB}")
  3.         MessageBox.Show("OK")
  4.         e.Handled = True
  5.     End If
#5 09.03.2018 08:15
xl_kid Van mreze
Postovi:154
Javlja mi grešku
e.keychar is not a member of system.windows.forms.KeyEventArgs
probao sam na Private Sub PorudzbineDetaljiDataGridView_KeyPress ali se ne deÅ¡ava niÅ¡ta. Ide red dole umesto sledeće polje.
#6 09.03.2018 10:57
Postovi:1,830
Moras setirati DataGridView.EditMode kao EditOnEnter da bi radio ova :
  1. Private Sub dgvMyGrid_KeyDown(ByVal sender As Object, ByVal e As System.Windows.Forms.KeyEventArgs) Handles dgvMyGrid.KeyDown
  2.     Select Case e.KeyCode
  3.         Case Keys.Enter
  4.             e.Handled = True
  5.             SendKeys.Send("{TAB}")
  6.         End Select
  7.     End Sub
#7 09.03.2018 10:59
Postovi:1,830
Eve uste edno resenie probaj go i ova
  1. Private Const WM_KEYDOWN = &H100
  3. Protected Overrides Function ProcessKeyPreview(ByRef m As System.Windows.Forms.Message) As Boolean
  4. Dim keyCode As Keys = CType(m.WParam.ToInt32() And Keys.KeyCode, Keys)
  5. If m.Msg = WM_KEYDOWN And keyCode = Keys.Enter Then
  6. SendKeys.Send("{TAB}")
  7. Return True
  8. End If
  9. Return MyBase.ProcessKeyPreview(m)
  10. End Function
#8 09.03.2018 11:09
xl_kid Van mreze
Postovi:154
Opet ide red ispod.
#9 09.03.2018 11:28
xl_kid Van mreze
Postovi:154
Hajde da pitam... Možda ovo Å¡to radim nije ispravno. DataGridView sam stavio da mi bude kao u access subforma. U prvom polju (1) unosim Å¡ifru proizvoda u drugom (2)mi automatski izlazi naziv proizvoda (to polje bi trebalo da preskočim i fokus da stavim na sledeće polje), (3) polje je za komade, (4) transportna pakovanja i (5) težina. Polja 3, 4 i 5 su numerička i tu se unosi ili komadi ili kutije ili težina.
#10 09.03.2018 11:54
Postovi:1,830
Ne bi trebalo biti problema.Ja kod mene isto tako radim samo razlikaje sto ne koristim standardni grid neko imam drugi grid.
Ovaj grid koj ja ga koristim ne radi vo vb.Net.
Znam da moze ova da se resi i sa standardni gridovi,100% nesto si propustio.
Nemam ja instalirano vb.Net da mogu da probam.
Sva vremena su GMT +02:00. Trenutno vrijeme: 3: 55 am.
