#1 19.01.2021 22:32
nevsad Van mreze
Registrovan od:01.09.2010
Postovi:231
Predmet:Application.FileSearch
Dim fs
Set fs = Application.FileSearch
With fs
.LookIn = "C:\windows"
.FileName = "print.txt"
If .Execute > 0 Then
'coddd...
End With
ovaj kod funkcionira u 2003
Å¡ta je zajenaa za FileSearch u 2007
unaprijed hvala
#2 20.01.2021 10:55
Postovi:1,830
Predmet:Re: Application.FileSearch
Kod je isti i za 2007 samo verovatno nisu ti reference ucitane isto kao i u 2003
#3 20.01.2021 11:38
Imas u arhivi zamjenu odnosno vb funkcij
https://icentar.ba/...t&id=7179
  1. Function DirFajl(Putanja As String, Optional Kriterija As String = "*")
  2. On Error GoTo Error_Handler
  3.     Dim Fajl As String
  5.     Fajl = Dir(Putanja & "*." & Kriterija)
  6.         Do While Fajl <> vbNullString
  7.             If Fajl <> "." And Fajl <> ".." Then
  8.                     Debug.Print "- " & Fajl
  9.             End If
  10.             Fajl = Dir
  11.         Loop
  13. Error_Handler_Exit:
  14.     On Error Resume Next
  15.     Exit Function
  16.
  17. Error_Handler:
  18.     MsgBox "The following error has occured." & vbCrLf & vbCrLf & _
  19.             "Error Number: " & Err.Number & vbCrLf & _
  20.             "Error Source: DirFajl" & vbCrLf & _
  21.             "Error Description: " & Err.Description, _
  22.             vbCritical, "An Error has Occured!"
  23.     Resume Error_Handler_Exit
  24. End Function
#4 20.01.2021 13:41
nevsad Van mreze
Postovi:231
koja tacno referenca mora biti zakacena
hvala
#5 20.01.2021 22:57
Na osnovu onoga sto si dao tebi treba da provjeris dali fajl postoji u nekom dir.
Ako sam u pravu evo rjesenje.
Ovu funkciju stavi u neki modul.
  1. Function FileExists(Putanja As String, Optional ImeFajla As String) As Boolean
  3. Dim Fajl As String, PathStr As String
  5.  If Right(Putanja, 1) = "/" Or Right(Putanja, 1) = "\" Then
  6.  PathStr = Putanja & ImeFajla
  7.  Else
  8.   PathStr = Putanja & "/" & ImeFajla
  9.  End If
  10.         If Dir(PathStr) <> "" Then
  11.            FileExists = True
  12.            Exit Function
  13.         End If
  15. Error_Handler_Exit:
  16.     On Error Resume Next
  17.     FileExists = False
  18.     Exit Function
  19.
  20. Error_Handler:
  21.     MsgBox "The following error has occured." & vbCrLf & vbCrLf & _
  22.             "Error Number: " & Err.Number & vbCrLf & _
  23.             "Error Source: DirFajl" & vbCrLf & _
  24.             "Error Description: " & Err.Description, _
  25.             vbCritical, "An Error has Occured!"
  26.     Resume Error_Handler_Exit
  27. End Function
funkciju pozivas:
Dim a as boolean
a=FileExists("d:/temp","SYS.MDW")
Vraca true ako ima a false ako nema fajla
#6 21.01.2021 01:18
nevsad Van mreze
Postovi:231
to je to...
na open forme, loga, provjeri da li postoji neki fajl
pa ide dalje ili izlazi
ova konamda ne postoji u 2007
dosta stvari korisnih ima na
https://www.access-programmers.co.uk/
fino hvala
jos uvijek nisam siguran da cu pobjeci od 2003
exsperimentiram sa 2007
Sva vremena su GMT +02:00. Trenutno vrijeme: 2: 05 pm.
