#1 05.04.2022 13:43
Postovi:4,710
Predmet:VBA scraping
mozda znate kako bi skinuo viceve sa web stranice u excel?
web stranica: https://icentar.ba/icentar/showtopic.php?id=22
  1. Sub test()
  3. the_start:
  5.     Set objIE = CreateObject("InternetExplorer.Application")
  6.     objIE.Top = 0
  7.     objIE.Left = 0
  8.     objIE.Width = 800
  9.     objIE.Height = 600
  10.     objIE.Visible = False 'We will see the window navigation
  12.     On Error Resume Next
  13.     objIE.Navigate ("https://icentar.ba/icentar/showtopic.php?id=22")
  15.     Do
  16.     DoEvents
  17.         If Err.Number <> 0 Then
  18.             objIE.Quit
  19.             Set objIE = Nothing
  20.             GoTo the_start:
  21.         End If
  22.     Loop Until objIE.ReadyState = 4
  23.
  24.     MsgBox "webpage has loaded"
  25.
  26.     Dim AllString As String
  27.
  28.     Set Alllinks = objIE.Document.getElementsByTagName("a")
  29.     For Each Hyperlink In Alllinks
  30.         If InStr(Hyperlink.innerText, "Haso") > 0 Then
  31.             AllString = Hyperlink.innerText
  32.             Exit For
  33.         End If
  34.     Next
  35.
  36.     MsgBox AllString
  37.
  38. End Sub
#2 09.04.2022 11:48
Predmet:Re:VBA scraping
Nece niko ni da proba.
  1. Function test()
  3. the_start:
  6.     objIE.Top = 0
  7.     objIE.Left = 0
  15.     Do
  16.     DoEvents
  18.             objIE.Quit
  20.             GoTo the_start:
  21.         End If
  23.
  24.
  25.     Dim AllString As String
  26.
  27.     Set Alllinks = objIE.Document.getElementsByTagName("div")
  28.     For Each Hyperlink In Alllinks
  29.        ime = Hyperlink.className
  30.         If ime = "bbody iefix_left" Then
  32.              MsgBox AllString
  33.             MsgBox Hyperlink.Name
  34.              'Exit For
  35.        End If
  36.     Next
  37.
  38. Set objIE = Nothing
  39. End Function
#3 10.04.2022 15:02
Dobar dan.
Isprobavam ovo i funkcija radi kada ju pokrenem u VBA editoru. Za Access znam ali mi nije potpuno jasno kako se funkcija poziva kada se otvoru Excel sheet?
#4 12.04.2022 09:51
Postovi:4,710
Citiraj pmiroslav:
Dobar dan.
ja sam to napravio ovako:
u module1 dodao sam jos ovo:
Sub proba()
Call test
zatim sam na List1 stavio tipku na ovaj nacin:
cijeli kod. Nakon sto se pokaze vic ako pritisnemo OK, pokaze sljedeci vic a ako kliknemo na cancel vrati nas na List1 tj, izade iz funkcije
  1. Sub proba()
  2.         Call test
  3.     End Sub
  4.     Function test()
  5.         Dim odgovor
  6. the_start:
  8.         Set objIE = CreateObject("InternetExplorer.Application")
  9.         objIE.Top = 0
  10.         objIE.Left = 0
  11.         objIE.Width = 800
  12.         objIE.Height = 600
  13.         objIE.Visible = False 'We will see the window navigation
  15.         On Error Resume Next
  16.         objIE.Navigate ("https://icentar.ba/icentar/showtopic.php?id=22")
  17.
  18.         Do
  19.         DoEvents
  20.             If Err.Number <> 0 Then
  21.                 objIE.Quit
  22.                 Set objIE = Nothing
  23.                 GoTo the_start:
  24.             End If
  25.         Loop Until objIE.ReadyState = 4
  26.
  27.
  28.         Dim AllString As String
  29.
  30.         Set Alllinks = objIE.Document.getElementsByTagName("div")
  31.         For Each Hyperlink In Alllinks
  32.            ime = Hyperlink.className
  33.             If ime = "bbody iefix_left" Then
  34.                 AllString = Hyperlink.innerText
  35.
  36.                 odgovor = MsgBox(AllString, vbOKCancel)
  37.                 If odgovor = vbCancel Then Exit Function
  38.
  39.             End If
  40.         Next
  41.
  42.     Set objIE = Nothing
  43.     End Function
za svaku web stranicu drugacije treba prilagoditi kod jer ne sadrze sve tekst vica izmedu div, neke imaju u <a> ili <p>
Tako da ne postoji univerzalni kod za skidanje sadrzaja web stranice vec ga moramo rucno prilagoditi.
Treba sa firefox otvoriti web lokaciju a zatim izabrati u meniju firefoksa-vise alata-pokazi izvornu web stranicu i onda prouciti gdje se nalazi tekst koji zelimo skinuti i prilagoditi kod
Ovaj post je ureden 1 puta. Posljednja izmjena 12.04.2022 09:53 od strane Avko. ↑  ↓
#5 14.04.2022 01:28
funkcija se moze pozvati iz bilo koje celije kao i sve ostale gotove funkcije.
Mozes skinuti i cio sadrzaja ako nemas filtere u funkciji odnosno ako skidas od taga body.
Sva vremena su GMT +02:00. Trenutno vrijeme: 5: 21 pm.
