iCentar » Forum » Racunari i oprema » Programirannje i baze podataka » Access » MDE , ACCDE to EXE
#1 19.06.2011 11:39
roko Van mreze
Postovi:236
Predmet:MDE , ACCDE to EXE
Kako se neki ( ? ? pametni) bune zašto im se distribuira access app evo postavljam način kako da se napravi distribucija kvazi exe app. Koristio sam VB6 portable.
Osim što se formira exe Files App i ažuriria \Access\Security\Trusted Locations zbog sigurnosne lokacije i (trebalo bi ) radi sa runtime access koji je instaliran na mašini
1.Otvorite VB6 i kreirajte praznu formu
2. kopirajte kod
3.Treba postaviti
Private Const Naziv_App = "Naziv App"
Private Const Licenca_App = "App_licenca"
Private Const Siguna_Pozicija = "ImeKaoString"( \Access\Security\Trusted Locations\"ImeKaoString")
Private Const Moja_Frontbaza = "MYP.DLL"(Preimenuj te front bazu u NekoIme.dll ili ocx ili bilo koje ime i nastavak)Backend baza mora biti na istoj lokaciji kao i exe
  1. Public Enum REG_TOPLEVEL_KEYS
  2.  HKEY_CLASSES_ROOT = &H80000000
  3.  HKEY_CURRENT_CONFIG = &H80000005
  4.  HKEY_CURRENT_USER = &H80000001
  5.  HKEY_DYN_DATA = &H80000006
  6.  HKEY_LOCAL_MACHINE = &H80000002
  7.  HKEY_PERFORMANCE_DATA = &H80000004
  8.  HKEY_USERS = &H80000003
  9. End Enum
  10. Private Const REG_DWORD = 4
  11. Private Const REG_SZ = 1
  12. Private Declare Function RegCreateKey Lib _
  13.    "advapi32.dll" Alias "RegCreateKeyA" _
  14.    (ByVal Hkey As Long, ByVal lpSubKey As _
  15.    String, phkResult As Long) As Long
  16. Private Declare Function RegCloseKey Lib _
  17.    "advapi32.dll" (ByVal Hkey As Long) As Long
  18. Private Declare Function RegSetValueEx Lib _
  19.    "advapi32.dll" Alias "RegSetValueExA" _
  20.    (ByVal Hkey As Long, ByVal _
  21.    lpValueName As String, ByVal _
  22.    Reserved As Long, ByVal dwType _
  23.    As Long, lpData As Any, ByVal _
  24.    cbData As Long) As Long
  25.
  26. '''''''''''''''''''''
  27. Private Const Naziv_App = "EVD Evidencija rada"
  28. Private Const Licenca_App = "MojProgram_licenca"
  29. Private Const Siguna_Pozicija = "LocationEVD"
  30. Private Const Moja_Frontbaza = "MYP.DLL"
  31. ''''''''''''''''''''''''
  32. Private Function WriteStringToRegistry(Hkey As _
  33.   REG_TOPLEVEL_KEYS, strPath As String, strValue As String, _
  34.   strdata As String, reg As Boolean) As Boolean
  35. Dim bAns As Boolean
  36. On Error GoTo ErrorHandler
  37.    Dim keyhand As Long
  38.    Dim r As Long
  39.    If reg = False Then
  40.    r = RegCreateKey(Hkey, strPath, keyhand)
  41.    If r = 0 Then
  42.         r = RegSetValueEx(keyhand, strValue, 0, _
  43.            REG_SZ, ByVal strdata, Len(strdata))
  44.         r = RegCloseKey(keyhand)
  45.     End If
  46.     Else
  47.    Dim nVal As Long
  48.    nVal = "00000001"
  49.     r = RegCreateKey(Hkey, strPath, keyhand)
  50.    If r = 0 Then
  51.         r = RegSetValueEx(keyhand, strValue, 0, _
  52.            REG_DWORD, nVal, Len(nVal)) '''ByVal strdata, Len(strdata))
  53.        r = RegCloseKey(keyhand)
  54.     End If
  55.     End If
  56.    WriteStringToRegistry = (r = 0)
  57.
  58. Exit Function
  59.
  60. ErrorHandler:
  61.     WriteStringToRegistry = False
  62.     Exit Function
  63.
  64. End Function
  65.
  66. Private Sub Form_Load()
  67. On Error GoTo Err_Form_Load
  68.
  69. Dim objShell As Object
  70. Dim objKill As Object
  71. Dim office_path As String, app_path As String, reg_path As String, Description_path As String, AllowSubfolders_path As String
  72. Dim search_mode As Integer, i As Integer, verzija As Integer
  73.
  74. Set objShell = CreateObject("Wscript.Shell")
  75.
  76. objShell.run "taskkill.exe /F /IM EXCEL.EXE", 0, True
  77. objShell.run "taskkill.exe /F /IM MSACCESS.EXE", 0, True
  78. For i = 14 To 1 Step -1
  79. If Len(office_path) = 0 Then
  80. verzija = i
  81. office_path = objShell.RegRead("HKLM\SOFTWARE\Microsoft\Office\" & i & ".0\Access\InstallRoot\Path")
  82. reg_path = objShell.RegRead("HKCU\SOFTWARE\Microsoft\Office\" & i & ".0\Access\Security\Trusted Locations\" & Siguna_Pozicija & "\Path")
  83. Description_path = objShell.RegRead("HKCU\SOFTWARE\Microsoft\Office\" & i & ".0\Access\Security\Trusted Locations\" & Siguna_Pozicija & "\Description")
  84. AllowSubfolders_path = objShell.RegRead("HKCU\SOFTWARE\Microsoft\Office\" & i & ".0\Access\Security\Trusted Locations\" & Siguna_Pozicija & "\AllowSubfolders")
  85. End If
  86. Next
  87. If App.Path <> reg_path Then
  88. WriteStringToRegistry HKEY_CURRENT_USER, "Software\Microsoft\Office\" & verzija & ".0\Access\Security\Trusted Locations\" & Siguna_Pozicija, "Path", App.Path, False
  89. WriteStringToRegistry HKEY_CURRENT_USER, "Software\Microsoft\Office\" & verzija & ".0\Access\Security\Trusted Locations\" & Siguna_Pozicija, "Date", Now, False
  90.
  91. End If
  92. If Description_path <> Licenca_App Then
  93. WriteStringToRegistry HKEY_CURRENT_USER, "Software\Microsoft\Office\" & verzija & ".0\Access\Security\Trusted Locations\" & Siguna_Pozicija, "Description", Licenca_App, False
  94. End If
  95. If AllowSubfolders_path = "" Then
  96. WriteStringToRegistry HKEY_CURRENT_USER, "Software\Microsoft\Office\" & verzija & ".0\Access\Security\Trusted Locations\" & Siguna_Pozicija, "AllowSubfolders", "1", True
  97. End If
  98. If Len(office_path) = 0 Then
  99.     MsgBox "Microsoft(Runtime) Instalacija nije pronaena, Molim vas re-instalirajte Microsoft Office Access (Runtime).", vbCritical, "Program Error!"
  100.     End
  101. End If
  102. app_path = App.Path
  103. objShell.run Chr(34) & office_path & "MSACCESS.EXE" & Chr(34) & " " & Chr(34) & app_path & "\" & Moja_Frontbaza
  104. End
  105. Err_Form_Load:
  106. If Err.Number = -2147024894 Then
  107.     Resume Next
  108. Else
  109.     MsgBox Err.Description
  110. End If
  111. End Sub
preimenujte svoju front mdb u "MYP.DLL" i u isti folder stavite MDB_TO_EXE.exe
Informacije o tipu datoteke za:rar  MDB_TO_EXE.rar
Preuzimanja:615
Velicina datoteke:123.36 KB
#2 20.06.2011 08:56
Predmet:Re: MDE , ACCDE to EXE
Jeli mora biti MDE i drugo piše da preimenujem mdb u dll.Kako to napraviti.
#3 20.06.2011 09:35
roko Van mreze
Postovi:236
bilo što samo poziva "MYP.DLL" i otvara
meki.mdb ili neki.accdb ili nekabaza.mde rename = MYP.DLL
to ide uz ovaj exe u raru
poz..
#4 20.06.2011 14:29
E svaka čast na ovome.Nego može li se otvarati preko office 2003.Ja imam instaliran probni ovaj 2010 i 2003 pa mi otvara samo preko 2010,i kako mogu u funkciji da promjenim ovo MYP.dll da recimo bude neki moj naziv.Mada nije toliko važno.
#5 20.06.2011 16:00
Evo ovdje mijenjas.
#6 20.06.2011 17:26
roko Van mreze
Postovi:236
ako baš hočeš da se otvara određena verzija samo makni u kodu
pa definirašda je i = 11 je 2003 ili 12 je 2007 ili 14 je 2010
( a 15 če biti 2012 )
poz..
#7 21.06.2011 09:03
Prava stvar, baš ću sad probati sam napravit preko vb6.
#8 23.06.2011 00:19
Evo i moj jedan.
Nemora se ni nalaziti na putanji aplikacije. Mozete ga staviti bilo gdje. Kada se prvi put podigne trazit ce putanju do accessa i putanju do app.
Ukoliko pogresno dodijelite putanje izbrisite samo file koji se napravi app.sys.
Informacije o tipu datoteke za:zip  startup.zip
Preuzimanja:593
Velicina datoteke:6.27 KB
#9 24.06.2011 10:16
Ovo je sad prava stvar , znači mogu svoju bazu preimenovati kako hoću sa nastavkom .dll ?
Ovo je prava stvar znači sa ovim izbjegavamo Shift Enter.Ja već imam zaštitu i to koristim na svojim aplikacijama a to je zaštita od kopiranja na drugo računalo.To je ono sa čitanjem serijskog broja diska.Ovo je za TOP TRICK ili tako nekako. Happy In love In love In love
Ovaj post je ureden 1 puta. Posljednja izmjena 24.06.2011 10:18 od strane miro35. ↑  ↓
#10 24.06.2011 10:47
Dešava mi se da prvi put pali program a drugi put kad ulazim javlja mi ovu grešku:
Preuzimanja:500
Velicina datoteke:11.52 KB
Velicina slike: 440 x 117 Pikseli
Sva vremena su GMT +01:00. Trenutno vrijeme: 11: 15 pm.
