iCentar » Forum » Racunari i oprema » Programirannje i baze podataka » Access » Ribbon XML / Controls
#21 23.04.2012 07:39
roko Van mreze
Postovi:236
Predmet:Re: Ribbon XML / Controls
daj i nazive forma ?
#22 23.04.2012 08:55
roko Van mreze
Postovi:236
to ti je samo meni
  1. <customUI xmlns="http://schemas.microsoft.com/office/2009/07/customui" onLoad="OnRibbonLoad" loadImage="LoadImages">
  2.   <ribbon startFromScratch="false">
  3.     <tabs>
  4.       <tab id="tab1" label="Mati
  5. ni podaci" getVisible ="GetVisible">
  6.       </tab>
  7.       <tab id="tab0" label="Dokumenti" getVisible ="GetVisible">
  8.         <group id="grp0" autoScale="false" centerVertically="false" label="." getVisible ="GetVisible">
  9.           <menu id="mnudoc" size="large" itemSize="large" label="Dokumenti" imageMso="AcceptAndAdvance" getVisible="GetVisible" getEnabled="GetEnabled" >
  10.             <button id="btnulaz" label="Ulaz Robe (Primka)" imageMso="ReviewShareWorkbook" onAction="OnActionButton" getVisible="GetVisible" getEnabled="GetEnabled" />
  11.             <menu id="mnupov" itemSize="normal" label="Povrat Robe" imageMso="GroupPreviewTransitions" getVisible="GetVisible" getEnabled="GetEnabled" >
  12.             <button id="btn1umeni" label="Povrat1" onAction="OnActionButton" getVisible="GetVisible" getEnabled="GetEnabled" />
  13.             <button id="btn2umeni" label="povrat2" onAction="OnActionButton" getVisible="GetVisible" getEnabled="GetEnabled" />
  14.             </menu>
  15.             <!--tu ti je podmenija povrat ->
  16.             <button id="btnnar" label="Narudžba Dobavlja
  17. u" imageMso="CheckNames" onAction="OnActionButton" getVisible="GetVisible" getEnabled="GetEnabled" />
  18.             <button id="btnpredrac" label="Ponuda-Predra
  19. un" imageMso="AdpManageIndexes" onAction="OnActionButton" getVisible="GetVisible" getEnabled="GetEnabled" />
  20.             <button id="btnracotp" label="Ra
  21. un-Otpremnica" imageMso="ViewDraftView" onAction="OnActionButton" getVisible="GetVisible" getEnabled="GetEnabled" />
  22.             <button id="btnizd" label="Ra
  23. un-Diskont" imageMso="TranslationToolTip" onAction="OnActionButton" getVisible="GetVisible" getEnabled="GetEnabled" />
  24.             <button id="btnizdr" label="Izdatnica Robe" imageMso="ActionInsert" onAction="OnActionButton" getVisible="GetVisible" getEnabled="GetEnabled" />
  25.           </menu>
  26.         </group>
  27.       </tab>
  28.     </tabs>
  29.   </ribbon>
  30. </customUI>
kako promjeniÅ¡ size="large"(ribbon veličina ) itemSize="large"(meni veličina )na smal smanjit če ti dugmiće
Ovaj post je ureden 1 puta. Posljednja izmjena 23.04.2012 08:58 od strane roko. ↑  ↓
#23 23.04.2012 09:55
Evo za robno forme a evo čim stignem napisat ću i za financijsko i za kasu.Hvala ti za ovo.
Informacije o tipu datoteke za:doc  RobnoForme.doc
Preuzimanja:238
Velicina datoteke:28.5 KB
#24 23.04.2012 10:05
Evo Å¡ta bih želio postići ali imam ovaj program za pravljenje ribona samo može dva taba jer je sharwaere
Informacije o tipu datoteke za:bmp  Ribon.bmp
Preuzimanja:220
Velicina datoteke:1.37 MB
#25 23.04.2012 12:37
roko Van mreze
Postovi:236
<tabs>
<tab id="tab1" label="Matini podaci" getVisible ="GetVisible">
</tab>
dodaj ih koliko očeÅ¡ samo id="tab2" itd i pazi na zatvarače </tab>
#26 23.04.2012 13:45
Ako možeÅ¡ samo pogledati ovaj moj primjer da mi posložiÅ¡ malo ove module uglavnom neće da radi odnosno da otvara ribon.
Informacije o tipu datoteke za:rar  Miro.rar
Preuzimanja:232
Velicina datoteke:85.74 KB
#27 23.04.2012 15:05
roko Van mreze
Postovi:236
dodao sam ti još par modula da možeš mjenjati ribbon (plavi sivi crni ) i još moja dva iz nekog programa pa da po shemi ribbona možeš raditi svoje
poz..
Informacije o tipu datoteke za:rar  Miro_sub.rar
Preuzimanja:248
Velicina datoteke:144.56 KB
#28 24.04.2012 07:39
Hvala ti sad sam malo isprobavao,odlično je ovo.Puno si mi pomogao.Tek sam počeo sa ovim 2010 access-om.Kupio sam licencu.Izgleda da nisu samo kozmetičke promjene u odnosu na 2003 ver.Kad dođem do modula za ribone možda mi bude trebala pomoć,ali sam sad dosta toga naučio.
#29 24.04.2012 09:25
roko Van mreze
Postovi:236
you welcome Wink
#30 24.04.2012 14:46
JoÅ¡ me zanima da li može negdje sa neta da se skinu neke slike za ove menije.Znači izgled slike i njen točan naziv da ga mogu upisati u xml.Ti si dao neke primjere.Koliko vidim ovo se da uljepÅ¡avati.
Stranice (8):1,2,3,4,5,6,7,8
Sva vremena su GMT +01:00. Trenutno vrijeme: 2: 53 am.
