iCentar » Forum » Racunari i oprema » Programirannje i baze podataka » Access » backup podataka splitovane baze
#1 06.06.2012 20:31
nevsad Van mreze
Registrovan od:01.09.2010
Postovi:237
Predmet:backup podataka splitovane baze
nešto ne valja za backup baze:koliko se sjecam trebala bi riješiti backup splitovane accessove baze ali mi ne prolazi nemam ideje
Function BackupDatabase()
Dim strSource As String, strOutput As String, strBackup As String, strDate As String,
Dim strFileName As String, strSource2 As String
With Access.Application
' Get Database File Name and Path
strBackup = .CurrentProject.Path
strSource = .CurrentProject.FullName
strFileName = .CurrentProject.Name
' Create a backup folder in the same directory if one doesn't already exist
strOutput = strBackup & "\Backup\"
If Not Dir(strOutput, vbDirectory) > vbNullString Then MkDir strOutput
' Copy the database from Source to Output
Dim fso As FileSystemObject
Dim db As New Access.Application
Set fso = New FileSystemObject
fso.CopyFile strSource, strOutput
Dim sWinZip As String
Dim sZipFile As String
Dim sZipFileName As String
Dim sFileToZip As String
sWinZip = "C:\Program Files\WinRar\WinRar.exe" 'Location of the WinRar program
sZipFileName = Left(strFileName, InStr(1, strFileName, ".", vbTextCompare) - 1) & _
" " & Format(Date, "dd.mm.yyyy") & " " & Format(Time, "hh.mm.ss") & ".rar"
sZipFile = strOutput & sZipFileName
sZipFile = Chr(34) & sZipFile & Chr(34)
sFileToZip = strOutput & strFileName
sFileToZip = Chr(34) & sFileToZip & Chr(34)
strOutput = Chr(34) & strOutput & Chr(34)
Call Shell(sWinZip & " a -ep " & sZipFile & " " & sFileToZip)
Beep
MsgBox "Backup copy is saved at " & Chr(13) & Chr(13) & strOutput &_
Chr(13) & Chr(13) & "Ôà¼ë ñå çîâå " & Chr(13) & Chr(13) & sZipFileName, vbInformation, "Backup successful!"
Set fso = Nothing
Kill strBackup & "\Backup\" & strFileName
Beep
End With
End Function
aplikacija je na c:\data\plata.mdb
baza je na C:\data\plata_be.mdb
za backup bi trebalo biti Plata_be+datum
svaka ideja je dobro došla
#2 07.06.2012 10:06
Predmet:Re: backup podataka splitovane baze
U modulu u reference moraš dodati 'Microsoft Scripting Runtime'
C:\Windows\System32\scrrun.dll
Ja sam sa tim probao i kod mene radi. Napravljena mi je datoteka 'Plata 07.06.2012 11.01.20.rar'
Ovaj post je ureden 1 puta. Posljednja izmjena 07.06.2012 10:07 od strane pmiroslav. ↑  ↓
#3 08.06.2012 18:11
nevsad Van mreze
Postovi:237
U modulu u reference sam dodao 'Microsoft Scripting Runtime'
i compajler me vati na
koristim access 2003
#4 08.06.2012 23:33
asto ne koristis stari i besplatan pkzip i pkunzip.
Em su mali em dobro rade.
#5 09.06.2012 00:10
Netreba ti fso.
Dovoljno je:
FileCopy strSource, strOutput
a izbrisi:
#6 09.06.2012 15:36
nevsad Van mreze
Postovi:237
fino hvala napravio sam
jel misliš da sa bat fajlom poziva pkzip po izlazu iz aplikacije
nevsad
#7 09.06.2012 15:38
nevsad Van mreze
Postovi:237
nisam ga koristio još od clippera i zabaravio sam na njega
nevsad
#8 09.06.2012 20:38
Predmet:Backup sa zipom
  1. Function Bekap()
  2. Dim StaroIme As String
  3. Dim NovoIme As String
  4. Dim Ime As String
  5. Dim Putanja As String
  7. On Error GoTo Kraj
  8. StaroIme = ImeBaze
  9. Putanja = PutanjaB
  10. NovoIme = Year(Date) & Format(Month(Date), "mm") & Format(Day(Date), "dd")
  11. NovoIme = Putanja & "backup\" & NovoIme & ".zip"
  12. Shell Putanja & "Pkzip " & NovoIme & " " & StaroIme
  13. MsgBox "Rezervna kopija baze zapisana na putanji." & vbCr & NovoIme
  14. Exit Function
  15. Kraj:
  16. GreskaB (Err.Number)
  17. End Function
  18.
  19. Function ImeBaze()
  20. Dim Ime As String
  21.
  22. Ime = CurrentDb.Name
  23.
  24. Do Until Right$(Ime, 1) = "."
  25. Ime = Left$(Ime, Len(Ime) - 1)
  26. Loop
  27. Ime = Left$(Ime, Len(Ime) - 1)
  28. ImeBaze = Ime & "_be.mdb"
  29. End Function
  30.
  31. Function PutanjaB()
  32. Dim Putanja As String
  33.
  34. Putanja = CurrentDb.Name
  35.
  36. Do Until Right$(Putanja, 1) = "\"
  37. Putanja = Left$(Putanja, Len(Putanja) - 1)
  38. Loop
  39. PutanjaB = Putanja
  40. End Function
Informacije o tipu datoteke za:zip  zip.zip
Preuzimanja:301
Velicina datoteke:69.33 KB
Ovaj post je ureden 1 puta. Posljednja izmjena 15.06.2012 08:31 od strane zxz. ↑  ↓
#9 10.06.2012 13:51
Ja sam ovo isprobao i za početak javlja se greška u funkciji Bekap() u dijelu
Kraj:
'Sub or Function not defined'
Taj dio sam isključio i nakon toga se napravi backup kopija imenom '201219.zip'.
Jedino je po meni mana što nakom novog pokretanja funkcije nova Backup kpoija pregazi sraru, a dobro bi bilo da se uvjek napravi kpoija sa novim imenom jer nekada treba imati i kpoiju baze od prije nekoliko dana ili čak mjeseci.
#10 10.06.2012 13:55
Svaki dan nova ali ne svaki sat i svaki minut, to gazi jedno preko drugoga.
Proijeni datum na compu pa probaj.
uf neznamgdje sa pobrljao zbog te greske pogledat cu.
To sam kopirao moju stim da ja tu imam svasta naesto.
Kao napr proceduru uspori shell koja zaustavlja dok se ne napravi zip.
Staviti cu tu proceduru u arhivu.
Stranice (4):1,2,3,4
Sva vremena su GMT +01:00. Trenutno vrijeme: 2: 35 am.
