iCentar » Forum » Racunari i oprema » Programirannje i baze podataka » Access » Bar kod čitac i SetFocus
#1 14.08.2012 16:14
Amelasar Van mreze
Registrovan od:07.04.2011
Postovi:344
Predmet:Bar kod čitac i SetFocus
Bar kod se spaja na COM port.
Slijedeci kod koristim (pomogao mi je Gjoreski):
  1. Private Sub MSComm1_OnComm()                                    ' Linija 1
  2.  Static stEvent1             As String                          ' Storage for an Modem event
  3.  Dim stComChar              As String * 1                       ' Temporary storage for received comm port data
  4.      Select Case msComm1.CommEvent
  5.         Case comEvReceive                                       ' Received RThreshold # of chars.
  6.                  Do
  7.                stComChar = msComm1.Input                        ' read 1 character .Inputlen = 1
  8.                 Select Case stComChar
  9.                     Case vbLf                                   ' Ignore linefeeds
  10.                     Case vbCr                                   ' The CR indicates the end of the Receive String
  11.                         If Len(stEvent1) > 0 Then
  12.                           ProcessEvent1 stEvent1                  ' Process the Modem event
  13.                           stEvent1 = ""
  14.                         End If
  15.                     Case Else
  16.                         stEvent1 = stEvent1 + stComChar           ' Save everything between CR's
  17.             End Select
  18.          Loop While msComm1.InBufferCount                       ' Loop until all characters in receive buffer are processed
  19.      End Select
  20. End Sub
  1. Private Sub Form_Unload(Cancel As Integer)
  2.      If msComm1.PortOpen Then
  3.         msComm1.PortOpen = False
  4. End If
  1. Private Sub Form_Load()
  3.  Dim CommPort As String
  5.  msComm1.CommPort = 1                                ' Opcija porta
  6.  msComm1.Settings = "4800,N,8,1"
  7.  If CommPort <> "" Then msComm1.CommPort = CommPort
  8.  msComm1.PortOpen = True
  9.  msComm1.DTREnable = True
  10.  msComm1.RTSEnable = True
  11.  msComm1.RThreshold = 1                                    ' Generate a receive event on every character received
  12.  msComm1.InputLen = 1                                      ' Read the receive buffer 1 char at a time
  13. End Sub
  1. Private Sub ProcessEvent1(stEvent1 As String)                               ' Linija 1
  2. BarkodPolje = stEvent1
  3. End Sub
Kako da napravim provjeru da li se kursor nalazi na zeljenoj poziciji? Jednostavno da iskljucim bar kod ako nije na zeljenom polju. Nadam se da sam bila razumljiva.
Pokusavala sam nesto kao:
If BarkodPolje.SetFocus=True then
dalje
else
end if
Ocigledno tako neide. Svaka pomoc bi dobro dosla.
Hvala.
Pozdrav, Amela
Ovaj post je ureden 1 puta. Posljednja izmjena 14.08.2012 16:17 od strane Amelasar. ↑  ↓
#2 14.08.2012 16:47
Predmet:Re: Bar kod čitac i SetFocus
Na on enter polja bar koda ukljuci proceduru a na on exit iskljuci.
Nemogu ovo sve da sagledam jer nedostaje koda vjerovatno ali mi nije jasno da moras otvarati com port za bat kod citac.
Doduse neznam kakav je.
Inace barkod citaci rade bez otvaranja com porta.
Znaci mozes unijeti podatak i u vordu bez ikakvog programiranja.
Najbolje bi bilo da zakacis tu formu i procedure ako sama ne uspijes napraviti ovo gore sto sam napisao.
#3 14.08.2012 17:19
Amelasar Van mreze
Postovi:344
To su barkod citaci koji se spajaju na tastaturu ili usb i za njih ne treba nikakvo programiranje.
Ovaj se spaja na com port i zbog toga treba sve programirati.
Sav kod je tu nista nisam preskocila. Com port se otvara kada ulazim na formu (Form_Load) i zatvara kada izlazim iz forme (Form_Unload).
Sto se tice barkod-a sve funkcionise.
Problem je ako ocitam bar kod a nalazim se bilo gdje na formi ide mi na polje:
Znaci trebam samo napraviti provjeru gdje se kursor nalazi i to dodati u gornji kod.
Ako je kursor na polju BarkodPolje upisi barkod sa com porta, a ako nije nista se ne desava.
To mi je potrebno ako korisnik greskom pritisne skeniranje.
Ili na drugi nacin da pokusam objasniti: Kako provjeriti da li se kursor nalazi na nekom polju?
Hvala.
Pozdrav, Amela
Ovaj post je ureden 1 puta. Posljednja izmjena 14.08.2012 17:23 od strane Amelasar. ↑  ↓
#4 14.08.2012 20:18
Dim Provjera as Boolean
if provjera=true then
endif
Private Sub ProcessEvent1_Enter()
Provjera = True
Private Sub ProcessEvent1_Exit(Cancel As Integer)
Provjera = False
#5 14.08.2012 20:39
Ako ti je taj bar kod citac dostupan probaj ga ipak u vordu.
Trebalo bi da radi.
#6 14.08.2012 21:24
Amelasar Van mreze
Postovi:344
Dostupan mi je barcod i neradi u wordu.
Ovaj kod mi ne funkcionise. Mogu zakaciti primjer ali vam bez barcoda ne moze pomoci.
Kad ocitam barkod uvijek mi javi da se ne nalazim na pravom polju.
Hvala zxz na trudu.
Pozdrav, Amela
#7 14.08.2012 22:02
Ovo bi trebalo da funkcionise i mogu ja to provjeriti bez bar koda.
Zakaci primjer.
Na on enter trebalo bi da ukljuci pozivanje procedure a na on exit da je iskljuci.
#8 14.08.2012 22:04
Jesil ovo stavila na vrh modula ispod ono option explicit.
Nesmije biti unutar niti jedne procedure.
#9 14.08.2012 23:14
Amelasar Van mreze
Postovi:344
Sve sam stavila kako si objasnio. Evo primjer.
Rijesila sam sa Check kontrolom ali bi voljela da naucim i tvoj primjer.
Hvala.
Informacije o tipu datoteke za:rar  barcode.rar
Preuzimanja:295
Velicina datoteke:313.10 KB
Pozdrav, Amela
#10 14.08.2012 23:42
Evo probaj moj primjer.
Informacije o tipu datoteke za:zip  barcodezxz.zip
Preuzimanja:280
Velicina datoteke:413.98 KB
Sva vremena su GMT +01:00. Trenutno vrijeme: 2: 44 am.
