iCentar » Forum » Racunari i oprema » Programirannje i baze podataka » Access » Clasa Vo Access
#1 04.04.2014 00:30
Postovi:1,890
Predmet:Clasa Vo Access
IMAM EDNA CLASA KOJAVO VB6 RABOTI DOBRO ,SEGA MI TREBA OVAA CLASA DA JA UPOTREBAM VO EDNA ACCESS APLIKACIJA NO NESTO NE ODI .
DALI OVAA CLASA MOZE VOOPSTO DA SE KORISTI VO ACCESS?
  1. Option Explicit
  3. Dim WithEvents mComm As MSComm
  4. Dim m_PortOpen As Boolean
  5. Dim m_Settings As String
  6. Dim m_CommPort As Integer
  7. Dim m_DTREnable As Boolean
  8. Dim m_Handshaking As FlowControl
  9. Dim m_InBufferSize As Integer
  10. Dim m_InputLen As Integer
  11. Dim m_InputMode As Mode
  12. Dim m_OutBufferSize As Integer
  13. Dim m_RTSEnable As Boolean
  14. Dim m_CommEvent As Integer
  16. Event OnComm()
  17.
  18. Public Enum FlowControl
  19.     None = 0
  20.     XonXoff = 1
  21.     CTSRTS = 2
  22.     XonXoffCTSRTS = 3
  23. End Enum
  24.
  25. Public Enum Mode
  26.     Text = 0
  27.     Binary = 1
  28. End Enum
  29.
  30. Public Sub Output(Dat As Variant)
  31.   mComm.Output = Dat
  32. End Sub
  33.
  34. Public Property Get InBufferCount() As Integer
  35.   InBufferCount = mComm.InBufferCount
  36. End Property
  37.
  38. Public Property Get InputData() As Variant
  39.   InputData = mComm.Input
  40. End Property
  41.
  42. Public Property Get OutBufferCount() As Integer
  43.     OutBufferCount = mComm.OutBufferCount
  44. End Property
  45.
  46. Public Property Let PortOpen(ByVal NewValue As Boolean)
  47.     If m_PortOpen = False And NewValue = True Then
  48.         With mComm
  49.             .ParityReplace = ""
  50.             .Settings = m_Settings
  51.             .CommPort = m_CommPort
  52.             .DTREnable = m_DTREnable
  53.             .Handshaking = m_Handshaking
  54.             .InBufferSize = m_InBufferSize
  55.             .InputLen = m_InputLen
  56.             .InputMode = m_InputMode
  57.             .OutBufferSize = m_OutBufferSize
  58.             .RTSEnable = m_RTSEnable
  59.             .PortOpen = True
  60.         End With
  61.         m_PortOpen = True
  62.     ElseIf NewValue = False Then
  63.         mComm.PortOpen = False
  64.         m_PortOpen = False
  65.     End If
  66. End Property
  67.
  68. Public Property Get PortOpen() As Boolean
  69.     PortOpen = m_PortOpen
  70. End Property
  71.
  72. Private Sub Class_Initialize()
  73.     m_Settings = "9600, N, 8, 1"
  74.     m_CommPort = 1
  75.     m_InBufferSize = 1024
  76.     m_OutBufferSize = 1024
  77.     Set mComm = CreateObject("MSCOMMLIB.MSCOMM")
  78. End Sub
  79.
  80. Public Property Get CommPort() As Integer
  81.     CommPort = m_CommPort
  82. End Property
  83.
  84. Public Property Let CommPort(ByVal NewValue As Integer)
  85.     m_CommPort = NewValue
  86.     If m_PortOpen = True Then mComm.CommPort = NewValue
  87. End Property
  88.
  89. Public Property Get DTREnable() As Boolean
  90.     DTREnable = m_DTREnable
  91. End Property
  92.
  93. Public Property Let DTREnable(ByVal NewValue As Boolean)
  94.     m_DTREnable = NewValue
  95.     If m_PortOpen = True Then mComm.DTREnable = NewValue
  96. End Property
  97.
  98. Public Property Get Handshaking() As FlowControl
  99.     Handshaking = m_Handshaking
  100. End Property
  101.
  102. Public Property Let Handshaking(ByVal NewValue As FlowControl)
  103.     m_Handshaking = NewValue
  104.     If m_PortOpen = True Then mComm.Handshaking = NewValue
  105. End Property
  106.
  107. Public Property Get InBufferSize() As Integer
  108.     InBufferSize = m_InBufferSize
  109. End Property
  110.
  111. Public Property Let InBufferSize(ByVal NewValue As Integer)
  112.     m_InBufferSize = NewValue
  113.     If m_PortOpen = True Then mComm.InBufferSize = NewValue
  114. End Property
  115.
  116. Public Property Get InputLen() As Integer
  117.     InputLen = m_InputLen
  118. End Property
  119.
  120. Public Property Let InputLen(ByVal NewValue As Integer)
  121.     m_InputLen = NewValue
  122.     If m_PortOpen = True Then mComm.InputLen = NewValue
  123. End Property
  124.
  125. Public Property Get InputMode() As Mode
  126.     InputMode = m_InputMode
  127. End Property
  128.
  129. Public Property Let InputMode(ByVal NewValue As Mode)
  130.     m_InputMode = NewValue
  131.     If m_PortOpen = True Then mComm.InputMode = NewValue
  132. End Property
  133.
  134. Public Property Get OutBufferSize() As Integer
  135.     OutBufferSize = m_OutBufferSize
  136. End Property
  137.
  138. Public Property Let OutBufferSize(ByVal NewValue As Integer)
  139.     m_OutBufferSize = NewValue
  140.     If m_PortOpen = True Then mComm.OutBufferSize = NewValue
  141. End Property
  142.
  143. Public Property Get RTSEnable() As Boolean
  144.     RTSEnable = m_RTSEnable
  145. End Property
  146.
  147. Public Property Let RTSEnable(ByVal NewValue As Boolean)
  148.     m_RTSEnable = NewValue
  149.     If m_PortOpen = True Then mComm.RTSEnable = NewValue
  150. End Property
  151.
  152. Public Property Get CDHolding() As Boolean
  153.     If m_PortOpen = True Then CDHolding = mComm.CDHolding
  154. End Property
  155.
  156. Public Property Get CTSHolding() As Boolean
  157.     If m_PortOpen = True Then CTSHolding = mComm.CTSHolding
  158. End Property
  159.
  160. Public Property Get DSRHolding() As Boolean
  161.     If m_PortOpen = True Then DSRHolding = mComm.DSRHolding
  162. End Property
  163.
  164. Private Sub Class_Terminate()
  165.     Set mComm = Nothing
  166. End Sub
  167.
  168. Public Property Get CommEvent() As Integer
  169.     CommEvent = m_CommEvent
  170. End Property
  171.
  172. Private Sub mComm_OnComm()
  173.     m_CommEvent = mComm.CommEvent
  174.     RaiseEvent OnComm
  175.     m_CommEvent = 0
  176. End Sub
  177.
  178. Public Property Get RThreshold() As Integer
  179.     RThreshold = mComm.RThreshold
  180. End Property
  181.
  182. Public Property Let RThreshold(ByVal NewValue As Integer)
  183.     mComm.RThreshold = NewValue
  184. End Property
#2 04.04.2014 07:49
Predmet:Re: Clasa Vo Access
Enum ne podrzava accessov vb-a, bar ne ove nize verzije 2007 i dalje nisam probao.
Moze se to prepraviti pa umjesto enum u tvom slucaju konstnte koliko vidim.
Vidim da se radi o com portu pa bi mozda dobro bilo da opises sta zelis napraviti.
Pretpostavljam pokupiti neke podatke sa com porta na koji je prikopcan neki uredjaj.
#3 04.04.2014 13:31
Postovi:1,890
Tocno se rabotit za mscomm32.ocx controlata.
Imam programa za trgovija na malo odnosno Kasa , priem na roba i uste nekolku vakvi formi.
Na site ovie formi imam po edna mscomm controla koja ja koristam za barcod citaci koi se povrzuvaat na COM. Ovaa kontrola super funkcionira i sum nemal nikakvi problemi no sega mi se javi eden problem na Win8 64 bit , odnosno problemot e vo toa sto Accesot ne ja prepoznava controlata ,Controlata e registrirana i funkcionira no ne so access. Veke nekolku vreme se obiduvam da go resam ova no ne odi nekako mi e zkocena rabotava .Sakam da probam na ovaj nacin dali ke se resi problemot ili da baram druga kontrola.
#4 04.04.2014 14:00
Uf nemam win 8 pa nemogu isprobati ali sigurno postoji druga kontrola i mozda 64-bitna.
#5 04.04.2014 14:52
Postovi:1,890
Moze ovaa Clasa da se preapravi i da probam da vidam sto ke bide , ne bi sakal da ja menuvam controlat
bidejki ke mi se otvori mnogu rabota a nemam vreme tolku da gubam ,ne se isplati.
#6 04.04.2014 17:12
  1. Option Compare Database
  2. Option Explicit
  4. Dim mComm As MSComm
  5. Dim m_PortOpen As Boolean
  6. Dim m_Settings As String
  7. Dim m_CommPort As Integer
  8. Dim m_DTREnable As Boolean
  9. Dim m_Handshaking As FlowControl
  10. Dim m_InBufferSize As Integer
  11. Dim m_InputLen As Integer
  12. Dim m_InputMode As Mode
  13. Dim m_OutBufferSize As Integer
  14. Dim m_RTSEnable As Boolean
  15. Dim m_CommEvent As Integer
  16.
  17.
  18.     Const None = 0
  19.     Const XonXoff = 1
  20.     Const CTSRTS = 2
  21.     Const XonXoffCTSRTS = 3
  22.
  23.
  24.
  25.    Const Text = 0
  26.    Const Binary = 1
  27.
  28.
  29. Public Sub Output(Dat As Variant)
  30.   mComm.Output = Dat
  31. End Sub
  32.
  33. Public Property Get InBufferCount() As Integer
  34.   InBufferCount = mComm.InBufferCount
  35. End Property
  36.
  37. Public Property Get InputData() As Variant
  38.   InputData = mComm.Input
  39. End Property
  40.
  41. Public Property Get OutBufferCount() As Integer
  42.     OutBufferCount = mComm.OutBufferCount
  43. End Property
  44.
  45. Public Property Let PortOpen(ByVal NewValue As Boolean)
  46.     If m_PortOpen = False And NewValue = True Then
  47.         With mComm
  48.             .ParityReplace = ""
  49.             .Settings = m_Settings
  50.             .CommPort = m_CommPort
  51.             .DTREnable = m_DTREnable
  52.             .Handshaking = m_Handshaking
  53.             .InBufferSize = m_InBufferSize
  54.             .InputLen = m_InputLen
  55.             .InputMode = m_InputMode
  56.             .OutBufferSize = m_OutBufferSize
  57.             .RTSEnable = m_RTSEnable
  58.             .PortOpen = True
  59.         End With
  60.         m_PortOpen = True
  61.     ElseIf NewValue = False Then
  62.         mComm.PortOpen = False
  63.         m_PortOpen = False
  64.     End If
  65. End Property
  66.
  67. Public Property Get PortOpen() As Boolean
  68.     PortOpen = m_PortOpen
  69. End Property
  70.
  71. Private Sub Class_Initialize()
  72.     m_Settings = "9600, N, 8, 1"
  73.     m_CommPort = 1
  74.     m_InBufferSize = 1024
  75.     m_OutBufferSize = 1024
  76.     Set mComm = CreateObject("MSCOMMLIB.MSCOMM")
  77. End Sub
  78.
  79. Public Property Get CommPort() As Integer
  80.     CommPort = m_CommPort
  81. End Property
  82.
  83. Public Property Let CommPort(ByVal NewValue As Integer)
  84.     m_CommPort = NewValue
  85.     If m_PortOpen = True Then mComm.CommPort = NewValue
  86. End Property
  87.
  88. Public Property Get DTREnable() As Boolean
  89.     DTREnable = m_DTREnable
  90. End Property
  91.
  92. Public Property Let DTREnable(ByVal NewValue As Boolean)
  93.     m_DTREnable = NewValue
  94.     If m_PortOpen = True Then mComm.DTREnable = NewValue
  95. End Property
  96.
  97. Public Property Get Handshaking() As FlowControl
  98.     Handshaking = m_Handshaking
  99. End Property
  100.
  101. Public Property Let Handshaking(ByVal NewValue As FlowControl)
  102.     m_Handshaking = NewValue
  103.     If m_PortOpen = True Then mComm.Handshaking = NewValue
  104. End Property
  105.
  106. Public Property Get InBufferSize() As Integer
  107.     InBufferSize = m_InBufferSize
  108. End Property
  109.
  110. Public Property Let InBufferSize(ByVal NewValue As Integer)
  111.     m_InBufferSize = NewValue
  112.     If m_PortOpen = True Then mComm.InBufferSize = NewValue
  113. End Property
  114.
  115. Public Property Get InputLen() As Integer
  116.     InputLen = m_InputLen
  117. End Property
  118.
  119. Public Property Let InputLen(ByVal NewValue As Integer)
  120.     m_InputLen = NewValue
  121.     If m_PortOpen = True Then mComm.InputLen = NewValue
  122. End Property
  123.
  124. Public Property Get InputMode() As Mode
  125.     InputMode = m_InputMode
  126. End Property
  127.
  128. Public Property Let InputMode(ByVal NewValue As Mode)
  129.     m_InputMode = NewValue
  130.     If m_PortOpen = True Then mComm.InputMode = NewValue
  131. End Property
  132.
  133. Public Property Get OutBufferSize() As Integer
  134.     OutBufferSize = m_OutBufferSize
  135. End Property
  136.
  137. Public Property Let OutBufferSize(ByVal NewValue As Integer)
  138.     m_OutBufferSize = NewValue
  139.     If m_PortOpen = True Then mComm.OutBufferSize = NewValue
  140. End Property
  141.
  142. Public Property Get RTSEnable() As Boolean
  143.     RTSEnable = m_RTSEnable
  144. End Property
  145.
  146. Public Property Let RTSEnable(ByVal NewValue As Boolean)
  147.     m_RTSEnable = NewValue
  148.     If m_PortOpen = True Then mComm.RTSEnable = NewValue
  149. End Property
  150.
  151. Public Property Get CDHolding() As Boolean
  152.     If m_PortOpen = True Then CDHolding = mComm.CDHolding
  153. End Property
  154.
  155. Public Property Get CTSHolding() As Boolean
  156.     If m_PortOpen = True Then CTSHolding = mComm.CTSHolding
  157. End Property
  158.
  159. Public Property Get DSRHolding() As Boolean
  160.     If m_PortOpen = True Then DSRHolding = mComm.DSRHolding
  161. End Property
  162.
  163. Private Sub Class_Terminate()
  164.     Set mComm = Nothing
  165. End Sub
  166.
  167. Public Property Get CommEvent() As Integer
  168.     CommEvent = m_CommEvent
  169. End Property
  170.
  171. Private Sub mComm_OnComm()
  172.     m_CommEvent = mComm.CommEvent
  173.     m_CommEvent = 0
  174. End Sub
  175.
  176. Public Property Get RThreshold() As Integer
  177.     RThreshold = mComm.RThreshold
  178. End Property
  179.
  180. Public Property Let RThreshold(ByVal NewValue As Integer)
  181.     mComm.RThreshold = NewValue
  182. End Property
#7 04.04.2014 20:18
Postovi:1,890
Ova ne odi nesto eve primer
Informacije o tipu datoteke za:rar  New Microsoft Office Access Application.rar
Preuzimanja:212
Velicina datoteke:16.46 KB
#8 04.04.2014 21:57
Pa nisi ukljucio u referencama mscomm32.ocx.
Nemoze bez njega jer ovo je klasa za njega.
#9 05.04.2014 01:49
Postovi:1,890
ja ukluciv ama ne raboti
#10 08.04.2014 08:56
Uf u ovom tvome kodu ima jos objekata koje ja nemogu da prepoznam sta su.
Evo ti moj primjer pa probaj.
Informacije o tipu datoteke za:zip  ComPort.zip
Preuzimanja:230
Velicina datoteke:12.28 KB
Sva vremena su GMT +01:00. Trenutno vrijeme: 4: 47 am.
