iCentar » Forum » Racunari i oprema » Programirannje i baze podataka » Access » Baza za evidenciju korisnika
#21 23.01.2015 22:31
Dado Van mreze
Registrovan od:27.10.2011
Postovi:276
Predmet:Re: Baza za evidenciju korisnika
Pau ovoj bazi u kojoj mi ova forma frmStanjeZFilt_QBF radi svi podaci se mogu filtrirati.
#22 24.01.2015 10:05
Nejasan si. Što znači "svi se podaci mogu filtrirati"? Podaci bi se trebali filtrirati po nekom kriteriju, npr:
-prikaži mi sve iz nekog mjesta
-prikaži mi sve iz neke općine
-prikaži mi sve koji su dobili određenu pomoć
itd.
To sve možeš dobiti sa formom frmPretraživanje koju sam stavio u primjeru.
A što bi Funkcija koju si stavio u prethodnom postu trebala raditi ja baš nisam siguran
#23 24.01.2015 14:35
Evo je
  1. Function glrDoQBF(strFormName As String, fCloseIt As Integer)
  3.     ' Load the specified form as a QBF form.  If
  4.     ' the form is still loaded when control returns
  5.     ' to this function, then it will attempt to
  6.     ' build an SQL WHERE clause describing the
  7.     ' values in the fields.  DoQBF() will return
  8.     ' either that SQL string or a null string,
  9.     ' depending on what the user chose to do and
  10.     ' whether or not any fields were filled in.
  12.     ' In:
  13.     '     strFormName: Name of the form to load
  14.     '     fCloseIt: Close the form, if the user didn't?
  15.     ' Out:
  16.     '     Return Value: The calculated SQL string.
  17.
  18.     Dim strSQL As String
  19.
  20.     DoCmd.OpenForm strFormName, WindowMode:=acDialog
  21.
  22.     ' You won't get here until user hides or closes the form.
  23.     ' If the user closed the form, there's nothing
  24.     ' to be done.  Otherwise, build up the SQL WHERE
  25.     ' clause.  Once you're done, if the caller requested
  26.     ' the QBF form to be closed, close it now.
  27.     If isFormLoaded(strFormName) Then
  28.         strSQL = BuildWHEREClause(Forms(strFormName))
  29.         If fCloseIt Then
  30.             DoCmd.Close acForm, strFormName
  31.         End If
  32.     End If
  33.     glrDoQBF = strSQL
  34. End Function
#24 26.01.2015 10:13
Dado Van mreze
Postovi:276
Evo citava procedura koja radi u jednoj drugoj bazi
ption Compare Database 'Use database order for string comparisons
Option Explicit
Const QUOTE = """"
Private Function BuildSQLString(strFieldName As String, varFieldValue As Variant, intFieldType As Integer)
' Build string that can be used as part of an
' SQL WHERE clause. This function looks at
' the field type for the specified table field,
' and constructs the expression accordingly.
Dim strTemp As String
strTemp = "[" & strFieldName & "]"
' If the first part of the value indicates that it's
' to be left as is, leave it alone. Otherwise,
' munge the value as necessary.
If isOperator(varFieldValue) Then
strTemp = strTemp & " " & varFieldValue
Else
Select Case intFieldType
Case dbBoolean
' Convert to TRUE/FALSE
strTemp = strTemp & " = " & CInt(varFieldValue)
Case dbText, dbMemo
' Assume we're looking for anything that STARTS with the text we got.
' This is probably a LOT slower. If you want direct matches
' instead, use the commented-out line.
' strTemp = strTemp & " = " & QUOTE & varFieldValue & QUOTE
strTemp = strTemp & " LIKE " & QUOTE & varFieldValue & "*" & QUOTE
Case dbByte, dbInteger, dbLong, dbCurrency, dbSingle, dbDouble
' Convert to straight numeric representation.
strTemp = strTemp & " = " & varFieldValue
Case dbDate
' Convert to #date# format.
strTemp = strTemp & " = " & "#" & varFieldValue & "#"
Case Else
' This function really can't handle any of the other data types (DB_BINARY?)
strTemp = ""
End Select
BuildSQLString = strTemp
End Function
Private Function BuildWHEREClause(frm As Form) As String
' Build the full WHERE clause based on fields
' on the passed-in form. This function attempts
' to look at all controls that have the correct
' settings in the Tag properties.
Dim intI As Integer
Dim strLocalSQL As String
Dim varDataType As Integer
Dim varControlSource As Variant
Dim ctl As Control
For intI = 0 To frm.Count - 1
Set ctl = frm(intI)
' Get the original control source.
varControlSource = adhCtlTagGetItem(ctl, "qbfField")
If Not IsNull(varControlSource) Then
' If the value of the control isn't null...
If Not IsNull(ctl) Then
' then get the value.
varDataType = adhCtlTagGetItem(ctl, "qbfType")
If Not IsNull(varDataType) Then
strTemp = "(" & BuildSQLString(CStr(varControlSource), ctl, CInt(varDataType)) & ")"
strLocalSQL = strLocalSQL & IIf(Len(strLocalSQL) = 0, strTemp, " AND " & strTemp)
On Error GoTo 0
Next intI
If Len(strLocalSQL) > 0 Then strLocalSQL = "(" & strLocalSQL & ")"
BuildWHEREClause = strLocalSQL
End Function
' In:
' Out:
If fCloseIt Then
glrDoQBF = strSQL
End Function
Function glrQBF_DoClose()
' Close the current form.
DoCmd.Close
End Function
Function glrQBF_DoHide(frm As Form)
Dim varSQL As Variant
Dim strParentForm As String
'Get the name of the Parent form
strParentForm = Left(CStr(frm.Name), Len(CStr(frm.Name)) - 4)
'Create the approprite Where clause based on the fields with data in them
varSQL = glrDoQBF(CStr(frm.Name), False)
'Open the Parent form filtered with the Where clause genereated above
DoCmd.OpenForm strParentForm, acNormal, , varSQL
'Make this *_QBF form invisible
frm.Visible = False
End Function
Private Function isFormLoaded(strName As String)
' Return a logical value indicating whether a
' given formname is loaded or not.
On Error Resume Next
isFormLoaded = (SysCmd(acSysCmdGetObjectState, acForm, strName) <> 0)
If Err.Number <> 0 Then
isFormLoaded = False
End Function
Private Function isOperator(varValue As Variant)
' value passed in is an operator or not.
' This is NOT infallible, and may need correcting.
Dim varTemp As Variant
varTemp = Trim(UCase(varValue))
isOperator = False
' Check first character for <,>, or =
If InStr("<>=", Left(varTemp, 1)) > 0 Then
isOperator = True
' Check for IN (x,y,z)
ElseIf ((Left(varTemp, 4) = "IN (") And (Right(varTemp, 1) = ")")) Then
isOperator = True
' Check for BETWEEN ... AND ...
ElseIf ((Left(varTemp, Innocent = "BETWEEN ") And (InStr(varTemp, " AND ") > 0)) Then
isOperator = True
' Check for NOT xxx
ElseIf (Left(varTemp, 4) = "NOT ") Then
isOperator = True
' Check for LIKE xxx
ElseIf (Left(varTemp, 5) = "LIKE ") Then
isOperator = True
End Function
#25 26.01.2015 10:20
Dado Van mreze
Postovi:276
Ove dvije forme frmStanjeZFilt i frmStanjeZFilt_QBF su mi vazne jer imam filter, karticu korisnika i export u excel. Sve na jednom jestu, ali samo mi nije jasno zbog cega ovaj filter frmStanjeZFilt_QBF ne radi.
#26 26.01.2015 11:26
O kojem filteru ti stalno govoriš. To što ti ovo radi u nekoj drugoj bazi ne znači da će sve isto raditi i u ovom tvom primjeru.
Dali je tebi uopće jasno kako procedure rade. Ti na formi frmStanjeZFilt ispod dugmeta koje se zove Filter imaš kod:
Dim stDocName As String
Dim stLinkCriteria As String
stDocName = "frmStanjeZFilt_QBF"
DoCmd.OpenForm stDocName, , , stLinkCriteria
taj kod nne radi ništa drugo nego otavra formu "frmStanjeZFilt_QBF"
Ispod dugmeta za eksport u excel imaš
directory = getpath(DB.Name)
Gdje ti je Funkcija getpath koja se ovdje poziva.
Stavi za primjer tu bazu gdje to sve radi pa da vidimo.
#27 26.01.2015 12:03
Dado Van mreze
Postovi:276
Možeš li mi napraviti kod da exportujem podatke u excel iz listboxa List30 koji je smješten u formi frmPretrazivanje, i da kada selektujem nekog korisnika na listboxu List30 klikom na dugme otvorim njegovu karticu pomoci i otprintam je. Ja bih pripremio reports.
#28 26.01.2015 14:05
Citiraj Dado:
To već imaš. Selektiraj korisnika i pritisni dugme PRIKAŽI KORISNIKA.
Za export u excel na formi za pretraživanje napravi dugme koje ćeš nazvati cmdExportToExcel i ispod njega kopiraj slijedeći kod
  1. Private Sub cmdExportToExcel_Click()
  2. On Error GoTo ErrorHandler
  4. Dim strTable As String
  5. Dim strWorksheetPath As String
  7. strWorksheetPath = "C:\Korisnici\"  'Ovdje napiši gdje da se sprema Excell datoteka
  8. strWorksheetPath = strWorksheetPath & "korisnici.xls"
  9. strTable = "qryPretrazivanjeAsc"
  10. DoCmd.TransferSpreadsheet transfertype:=acExport, _
  11. spreadsheettype:=acSpreadsheetTypeExcel9, _
  12. TableName:=strTable, _
  13. filename:=strWorksheetPath, _
  14. HasFieldNames:=True
  16. ErrorHandlerExit:
  17. Exit Sub
  18. ErrorHandler:
  19. MsgBox "Greška br: " & Err.Number _
  20. & "; Opis: " & Err.Description
  21. Resume ErrorHandlerExit
  22.
  23. End Sub
Sva vremena su GMT +02:00. Trenutno vrijeme: 4: 45 am.
