iCentar » Forum » Racunari i oprema » Programirannje i baze podataka » Access » Problem sa pretragom
#21 22.02.2015 15:11
Predmet:Re: Problem sa pretragom
Hehe ovo nemozes stic.
Dok napisases post vec dva imju nova neprocitana.
Imas gore post 18 sa rjesenjem a post 20 sa objasnjenjem.
#22 22.02.2015 15:14
Jasmin Van mreze
da uradio sam tako ali sad mi se ne vide podforme bez obzira ako upise ispravne ili neispravne podatke u search.
#23 22.02.2015 15:17
Daj stavi citav kod.
Znaci naslova do end. sve.
#24 22.02.2015 15:20
Jasmin Van mreze
Option Compare Database
Option Explicit
Dim Path As String
Private Sub txtSök_AfterUpdate()
Me.RecordSource = Me.RecordSource
Me.RecordsetClone.FindFirst "[Produktion] LIKE '" & Me![txtSök] & "'"
If Me.RecordsetClone.NoMatch Then
MsgBox "Search " & txtSök & " hittades inte!" & vbCrLf & "Gör ett nytt försök ? ", _
, "Söknings fel!"
txtSök.Value = ""
GoTo Kraj
Me.Bookmark = Me.RecordsetClone.Bookmark
Me.SUB_Produktion.Visible = False
Me.SUB_Test.Visible = False
Me.SUB_Anteckning.Visible = False
Else
Me.SUB_Test.SourceObject = Me.SUB_Test.SourceObject
txtSök.Value = ""
Exit Sub
Kraj:
#25 22.02.2015 15:29
evo ti.
  1. Option Compare Database
  2.  Option Explicit
  3.  Dim Path As String
  5.  Private Sub txtSök_AfterUpdate()
  8.  Me.SUB_Produktion.Visible = true
  9.  Me.SUB_Test.Visible = true
  10.  Me.SUB_Anteckning.Visible = true
  11.  Me.RecordSource = Me.RecordSource
  12.  Me.RecordsetClone.FindFirst "[Produktion] LIKE '" & Me![txtSök] & "'"
  13.  If Me.RecordsetClone.NoMatch Then
  14.  MsgBox "Search " & txtSök & " hittades inte!" & vbCrLf & "Gör ett nytt försök ? ", _
  15.  , "Söknings fel!"
  16.  txtSök.Value = ""
  17.  Me.SUB_Produktion.Visible = False
  18.  Me.SUB_Test.Visible = False
  19.  Me.SUB_Anteckning.Visible = False
  20.  GoTo Kraj
  21.  End If
  22.  Me.Bookmark = Me.RecordsetClone.Bookmark
  23.  Me.SUB_Test.SourceObject = Me.SUB_Test.SourceObject
  24.  txtSök.Value = ""
  25.  Exit Sub
  26.  Kraj:
  27.  End Sub
#26 22.02.2015 15:34
kenan Van mreze
Registrovan od:10.02.2011
Postovi:191
Znaci ovako ako korisník upise neku vrijednost koje nema u bazi treba da mu dodje ona obavjest da ta vrijednost ne postoji,
i kad klikne na "ok" da mu ostanu nevidljive podforme, sve dok ne bude upisao vrijednost koja postoji u bazi.
I samo u tom slucaju se otvaraju sve tri podforme i vidljive su.
UMJESTO MSGBOX SAMO KORISTI IF MSGBOX
If MsgBox("Želite spremiti podatke u policu?" & vbCrLf & "", vbYesNo, "eOsiguranje") = vbYes Then
EVO TI PRIMJER
#27 22.02.2015 15:42
Jasmin Van mreze
nece, javlja gresku ovdje
Ako promjenim na false na true onda radi.
Al' to nije to.
Kao sto napisah prije, ukoliko se unesu netacni podatci, onda mi ostaje samo ova SUB_Produktion podforma vidljiva, a ja ne zelim tako.
Ako se iz bilo kojih razloga desi da se upise neka vrijednost koja ne postoji u bazi onda ne trebaju da se vide ove tri podforme.
#28 22.02.2015 15:49
Neznam kako je stanje gdje ti je ovaj tater ispod kojeg je kod.
Ali na vidljivoj formi je vjerovatno polje za pretragu pa prije ovih napisi:
Me![txtSök].setfocus
#29 22.02.2015 16:03
Jasmin Van mreze
Keno/Zona ne radi opet Sad Sad
#30 22.02.2015 16:08
Uf nemoguce da ti to nemozes prebaciti u nizu verziju tj. 2007.
Koja ti je verzija accessa.
Ovako se igramo gluvih telefona.
Visible= false nece raditi ako je objekat u folkusu.
Uludo je to daj to snimi u 2007 verziju.
Stranice (5):1,2,3,4,5
Sva vremena su GMT +01:00. Trenutno vrijeme: 3: 02 am.
