iCentar » Forum » Racunari i oprema » Programirannje i baze podataka » Vb/Vbnet » Polijna i Formi
#11 24.10.2015 11:35
Predmet:Re: Polijna i Formi
Private Sub cmdOK_Click()
' If SoVreme = True Then Kade = StringToDatumVreme(txtData)
' If SoVreme = False Then Kade = StringToDatum(txtData)
Dim Frm As Form
Dim Ctl As Control
Set Frm = frmFi_Vardarec
Set Ctl = Frm("txtDataOD")
Ctl = StringToDatum(txtdata)
' Unload frmVnesNaData
Evo samo nisam imao tvoju kontrolu koju koristis za polja pa sam uzeo obicnu txt.
Moze samo biti do nje ako ne radi.
Znaci tvoje polje Txtdataod, txtdatado i txtdata je neka tvoja kontrola koju ja nemam.
#12 24.10.2015 11:42
to e standardna MSMask kontrola , no ne e problem moze da se proba i so text pole.
vaka raboti ne e problem
Dim Frm As Form
Dim Ctl As Control
treba vaka da raboti
NazivForma="frmFi_Vardarec"
NazivPole="txtDataOD"
Dim Frm As Form
Dim Ctl As Control
Set Frm = NazivForma
Set Ctl = Frm(NazivPole)
#13 24.10.2015 12:56
  1. Private Sub cmdOK_Click()
  3.    ' If SoVreme = True Then Kade = StringToDatumVreme(txtData)
  4.   ' If SoVreme = False Then Kade = StringToDatum(txtData)
  6.      Dim Frm As Form
  7.      Dim Ctl As Control
  8.      Dim NazivForma As String
  9.      Dim NazivPole As String
  10.      Dim Idx As Integer
  12.       NazivForma = "frmFi_Vardarec"
  13.       NazivPole = "txtDataOD"
  15.    For Each Frm In Forms
  16.     If Frm.Name = NazivForma Then
  17.    Exit For
  18.     End If
  19.    Next Frm
  20.      Set Ctl = Frm(NazivPole)
  21.      Ctl = StringToDatum(txtdata)
  22.   ' Unload frmVnesNaData
  23. End Sub
#14 24.10.2015 14:58
Toa e to fala mnogu.
Znaev jas deka e ova prasajne za iskusni.
Sva vremena su GMT +01:00. Trenutno vrijeme: 11: 17 pm.
