iCentar » Forum » iC » Test_forum » kacenje fajlova
Predmet:kacenje fajlova
proba kacenja fajlova
Informacije o tipu datoteke za:zip  SVozila.zip
Preuzimanja:509
Velicina datoteke:137 KB
Predmet:Re: kacenje fajlova
Connection closed by remote server
You tried to access the address http://www.icentar.ba/...&id=6071, which is currently unavailable. Please make sure that the web address (URL) is correctly spelled and punctuated, then try reloading the page.
Make sure your internet connection is active and check whether other applications that rely on the same connection are working.
Check that the setup of any internet security software is correct and does not interfere with ordinary web browsing.
If you are behind a firewall on a Local Area Network and think this may be causing problems, talk to your systems administrator.
Try pressing the F12 key on your keyboard and disabling proxy servers, unless you know that you are required to use a proxy to connect to the internet. Reload the page.
Need help?
idemo jos jednom,
da vidimo sada dali ide?
nema fajlova, radim li nesto krivo?
idemo probati samo jedan fajl
Warning: copy(): Filename cannot be empty in /home/icentarb/public_html/classes/class.upload.php on line 299
Poruka o greski:
duk.zip: Pristup je odbijen. Sustav nije mogao kopirati datoteke.
velicina fajla 3.48MB, ne prolazi. probat cemo jos
idemo probat za rar
nevidim fajlove, odustajem za danas
kacenje broj 2
Informacije o tipu datoteke za:zip  p2.zip
Preuzimanja:509
Velicina datoteke:26.13 KB
sta bi jel jos neko probao.
proba zakaciti fajl
Sva vremena su GMT +01:00. Trenutno vrijeme: 1: 31 pm.
