iCentar » Forum » Racunari i oprema » Softver i operativni sistemi » Rasterska grafika » Foto album
Predmet:Foto album
Ima li neko neki dobar program za foro album da je besplatan.
Dobro bi bilo da je i portable.
Predmet:Re: Foto album
ja sam koristio pikasu, pikasa je sada ukinuta pa vise ne koristim. Jednostavno imam fotografije u folderima slosezene po datumima i to je to.
Sothink Photo Album Maker is a program for creating photo album. It comes with all the necessary features and is simple to handle thanks to its nice and clear interface.
Key Features
Creation: this program allows users to import photos of their choices on the main interface to design a photo album or slideshow. Importing them can be done by a simple drag-and-drop of the mouse. The order of appearance of pictures can be arranged.
Transition effects: for creating a more original photo album, Sothink Photo Album Maker has been integrated with lots of transition effects that bring more fun to slideshows. It offers more than 100 items to obtain a vivid and dynamic album.
Editor: some functions for image editing has also been integrated to this program with an aim to enhance the output. For example, the user can crop, rotate and remove red eyes from an image. It also enables to adjust saturation and brightness.
Audio: apart from the ability to add text and pictures to the album, Sothink Photo Album Maker also makes it possible to add background sound. It supports MP3 file format as audio file.
Pros
Sothink Photo Album Maker is entirely free.
It is simple to install and uninstall.
It includes templates that can help in this case.
It offers an option to share the output on Web.
LINK
SkyAlbum Photo Gallery Builder
SkyAlbum Photo Gallery Builder is an easy to use software that helps you create stunning jQuery web photo gallery with a few mouse clicks. it takes a grouping of images and turns it into an flash-like image/photo gallery. It gives you freedom of displaying images galleries in most effective way for your own website.
Features
As easy as 1,2,3.
Dozens of professional jQuery web photo gallery themes.
Compatible with all web browsers
Support iPad, iPhone iOS brwoser, Andriod
No CSS, Javascript, HTML skills required
LINK
PORTABLE
SSuite Photo Gallery Portable is a program which allows you to easily create albums from your image files, in a user-friendly environment.
Since installation is not necessary, you can store SSuite Photo Gallery Portable on a removable device (like a USB flash drive), plug into any computer and directly run its executable file. But the most important fact is that your Windows registry keys will remain intact.
The interface of SSuite Photo Gallery Portable is simplistic and intuitive. You can create a new album by specifying its name and description, as well as edit the existing ones.
Images files (in the JPG or BMP format) can be imported into album by using the file browser. Batch selection is permitted through the "Open File" dialog box. You can view, rotate and copy pictures, write comments and edit their filenames, as well as move images and play a slideshow after setting the duration of each picture on the screen.
Features Available:
Print individual images
Export images separately
Move images to different albums
Insert bitmaps or jpegs of any size
Tag images with custom comments
View images in an image slide show
Create unlimited albums for image storage
Rotate function to correct upside down images
Export images as a single file {slide show}, viewable in any current web browser.
Minimum Requirements:
Runs on any USB devices
Screen Size - 800 x 600 Display Size
Runs on All Windows systems - 32 bit and 64 bit
LINK
Photo Gallery Generator Portable is a handy and accessible application designed to offer an easy method to create personalized albums from your favorite photos. Among its features, you can find a basic picture editor, customizations and the ability to import and edit the EXIF data for each item.
No setup necessary to run the program
The utility comes with all the necessary files packed in a small archive, which can be dropped on a USB flash drive and used on any computer. Make sure you have .NET Framework installed on the hard drive or updated to the newest version in order for the app to run smoothly and without issues.
The program offers a user-friendly and approachable interface divided into a file list, several gallery properties and all the provided functions stacked in a standard toolbar. Unfortunately, the icons are small, and it might take some time to get familiarized with their individual purpose.
Design your own gallery with preferred pictures
To start a new project, you have to go through a few essential steps. A new window is brought up, where you have to input a name and a title for the album, as well as the destination and source directories. The other settings can be easily configured at any given time. Once you have chosen the folder of origin, you have to hit the "Import" button for the items to be loaded into the panel and after you're done editing them, proceed to generate the gallery. Images are displayed in the index with their name, title, description, date, location path and size.
It's possible to set a specific photo size from the provided ones or manually input the desired width and height values. From the layout configuration, you can change the background image by picking a default one from the offered ones or a custom photo. In addition, you can personalize the displayed text with specific fonts and colors to best represent you.
Modify the records information and display the photos using the built-in viewer
You have the option to change the EXIF details for every picture, like the artist, copyright, description, original and modified date and more. You can open and adjust the brightness and contrast of an item by double-clicking on it. A double-panel is brought up, where you can view the original and altered photo. The collection is generated in HTM format and can be easily opened and viewed in your web browser. Plus, the tool lets you save the code to a TXT file to integrate the album in your website.
A few last words
To sum it up, Photo Gallery Generator is a reliable and clear-cut application created to provide an efficient way to generate and manage multiple picture galleries that can be exported to HTM format and enter it into your personal site.
LINK
Ovaj post je ureden 1 puta. Posljednja izmjena 04.12.2017 13:41 od strane Avko. ↑  ↓
trazi part04
imaju 4 programa. 2 su instalacijska (Sothink Photo Album Maker i SkyAlbum Photo Gallery Builder), a 2 su portable-bez instalacije (Photo Gallery Generator Portable i SSuite Photo Gallery Portable).
Svaki taj zip bi trebao rascjepkat na 10 i vise dijelova jer forum neda upload velike datoteke. Kada stavljam na forum neda mi vise od 3 datoteke po postu, pa bi trebao za 36 datoteka napisati 12 postova i onda spajati postove.
To mi se nije dalo pa sam stavio na google disk i postavio linkove koji su sakriveni iza LINK. Trebas kliknuti tamo gdje pise LINK pa ce ti skinuti sa moga google drajva.
ali ako zelis napravit cu ja i to sa postovima ili imas ti nekakvo drugo rijesenje?
evo link sa megaupload sva 4 programa u zip datoteci
fotoalbum.zip
Ovaj post je ureden 1 puta. Posljednja izmjena 04.12.2017 13:46 od strane Avko. ↑  ↓
32 partija,eto manje od 36
od 1 do 32, evo spojio.
33minute, kako vrijeme leti
Ja nasao na netu.
Jeli isto_
Isti je naziv.
nemoj me sada prekidat vidis da uploadam 32 fajla
hehehe
Informacije o tipu datoteke za:rar  fotoalbum.part05.rar
Preuzimanja:699
Velicina datoteke:700 KB
Informacije o tipu datoteke za:rar  fotoalbum.part03.rar
Preuzimanja:667
Informacije o tipu datoteke za:rar  fotoalbum.part04.rar
Preuzimanja:682
Informacije o tipu datoteke za:rar  fotoalbum.part02.rar
Preuzimanja:662
Informacije o tipu datoteke za:rar  fotoalbum.part01.rar
Preuzimanja:652
Informacije o tipu datoteke za:rar  fotoalbum.part06.rar
Preuzimanja:678
Informacije o tipu datoteke za:rar  fotoalbum.part07.rar
Preuzimanja:682
Informacije o tipu datoteke za:rar  fotoalbum.part08.rar
Preuzimanja:662
Informacije o tipu datoteke za:rar  fotoalbum.part09.rar
Preuzimanja:678
Informacije o tipu datoteke za:rar  fotoalbum.part10.rar
Preuzimanja:656
Informacije o tipu datoteke za:rar  fotoalbum.part11.rar
Preuzimanja:669
Informacije o tipu datoteke za:rar  fotoalbum.part12.rar
Preuzimanja:663
Informacije o tipu datoteke za:rar  fotoalbum.part13.rar
Preuzimanja:657
Informacije o tipu datoteke za:rar  fotoalbum.part14.rar
Preuzimanja:667
Informacije o tipu datoteke za:rar  fotoalbum.part15.rar
Preuzimanja:664
Informacije o tipu datoteke za:rar  fotoalbum.part16.rar
Preuzimanja:681
Informacije o tipu datoteke za:rar  fotoalbum.part17.rar
Preuzimanja:645
Informacije o tipu datoteke za:rar  fotoalbum.part18.rar
Preuzimanja:675
Informacije o tipu datoteke za:rar  fotoalbum.part19.rar
Preuzimanja:665
Informacije o tipu datoteke za:rar  fotoalbum.part20.rar
Preuzimanja:670
Informacije o tipu datoteke za:rar  fotoalbum.part21.rar
Preuzimanja:638
Informacije o tipu datoteke za:rar  fotoalbum.part22.rar
Preuzimanja:668
Informacije o tipu datoteke za:rar  fotoalbum.part23.rar
Preuzimanja:664
Informacije o tipu datoteke za:rar  fotoalbum.part24.rar
Preuzimanja:689
Informacije o tipu datoteke za:rar  fotoalbum.part25.rar
Preuzimanja:661
Informacije o tipu datoteke za:rar  fotoalbum.part26.rar
Preuzimanja:654
Informacije o tipu datoteke za:rar  fotoalbum.part27.rar
Preuzimanja:672
Informacije o tipu datoteke za:rar  fotoalbum.part28.rar
Preuzimanja:671
Informacije o tipu datoteke za:rar  fotoalbum.part29.rar
Preuzimanja:661
Informacije o tipu datoteke za:rar  fotoalbum.part30.rar
Preuzimanja:663
Informacije o tipu datoteke za:rar  fotoalbum.part31.rar
Preuzimanja:656
Informacije o tipu datoteke za:rar  fotoalbum.part32.rar
Preuzimanja:629
Velicina datoteke:485.34 KB
Ovaj post je ureden 14 puta. Posljednja izmjena 04.12.2017 14:14 od strane Avko. ↑  ↓
Ja nasao na netu.
Jeli isto_
Isti je naziv.
bolje da je tu na forumu. internet se moze srusiti, web stranice gdje su programi nestanu ali icentar ostaje zauvijek
hehehe
Citiraj Avko:
hehehe
I centar je poput feniksa, već se dizao iz pepela. Istina zXz je stvar pogurao ali...
Grinning
Sva vremena su GMT +01:00. Trenutno vrijeme: 10: 39 pm.
