iCentar » Forum » Racunari i oprema » Programirannje i baze podataka » Access » MSCOMM32 Win10 64Bit
#1 16.01.2018 10:38
Postovi:1,890
Predmet:MSCOMM32 Win10 64Bit
Mscomm32.ocx ne radi samo u Accesu ,a radi bez problema u Visual Basicu 6 ,
Ima li ko ideja sta moze biti.
Ovaj problem na Win7 32Bit smo resaali u registri ,ali ne prodze taj register na Win10 64Bit.
This ActiveX control has been disabled because of a security problem - see Microsoft Security Advisory (969898): Update Rollup for ActiveX Kill Bits.
You can enable it again (which makes your computer slightly more vulnerable) as follows. This involves editing the registry, so be careful.
- Start Regedit.
- Go to HKEY_LOCAL_MACHINE\Software\Microsoft\Internet Explorer\ActiveX Compatibility\{648A5600-2C6E-101B-82B6-000000000014}
- Change the value of Compatibility Flags from 0x0400 to 0.
#2 16.01.2018 23:17
Predmet:Re: MSCOMM32 Win10 64Bit
Ako mislis na mscomctl32.ocx
Ja sam ga bez problema ucitao i probao na frmi samo tree kontrolu.
#3 16.01.2018 23:20
Postovi:1,890
Ne mislam na mscomctl tuku tocno kako pisuva MSComm32.ocx.
Toa e ocx za rabota so seriska (rs232) porta
#4 17.01.2018 01:34
E ja taj nemam zakaci ga
#5 18.01.2018 10:28
Postovi:1,890
eve ja kontrolata
Informacije o tipu datoteke za:rar  MSCOMM32.rar
Preuzimanja:349
Velicina datoteke:41.62 KB
#6 19.01.2018 20:16
Postovi:1,890
Problemot e resen so pomos ActiveX Compatibility Manager v1.00
So ovaa alatka se vrsi Disable i Enable na OCX kontroli.
Ovaa e besplatna i dobro e sekoj da ja poseduva.
Kaj mene veke stana del od sekoja nova instalacija.
Vo prilog alatkata.
Informacije o tipu datoteke za:zip  acm.zip
Preuzimanja:328
Velicina datoteke:40.84 KB
#7 23.06.2018 20:03
kenan Van mreze
Registrovan od:10.02.2011
Postovi:191
Uradio sam sve kako si opisao preko ovog "ACM"-a tj. stavio da je Enable promjenio u registry ovo dole
- Start Regedit.
i opet neče
#8 23.06.2018 20:10
Postovi:1,890
Jesi li registrirao kontrolu?
Uymi regsvr32 od WinXP stavi ga da radi u compatibiliti mod kako WinXP SP3 i ovelezi ga uvek da se pokrena kao Administrator. i registriraj go OCXot.
#9 23.06.2018 20:51
kenan Van mreze
Postovi:191
sve sam uradio i nece
#10 23.06.2018 21:00
kenan Van mreze
Postovi:191
s tim da ja pokušavam da registrujem zxzbox.dll na
Win 10 64 bit
Access 2016 64 bit
Sva vremena su GMT +01:00. Trenutno vrijeme: 11: 31 am.
