iCentar » Forum » Racunari i oprema » Hardver i mreze » PS konfiguracije » racunalo se samo restarta
#11 21.05.2018 20:43
Predmet:Re: racunalo se samo restarta
hvala gjoreski, ako je do elktrolita zamijenit cu racunalo.
danas sam stavio ovo i nijednom se nije restartalo, vidjet cu kako dalje ide.
kaze da je mozda do odlaska racunala u sleep mod i hibernaciju, koliko sam ja shvatio
  1. Click Start, Click Control Panel,
  2. Look at the top of the window, in the path bar you see “control panel >”
  3. Click on “>” (in the path bar) now click on “all control panel options.”
  4. (This will open up all the hidden controls available)
  5. Click Power Options
  6. click on the arrow to “show other plans”
  7. Check the Box that says "high performance"
  8. Click (in high performance) "change plan settings"
  9. Turn off display: set to NEVER
  10. Put the computer to sleep: set to NEVER
  11. Click: Change advanced plan settings
  12. Scroll down the list: Click on the + signs to expand the choices for each item on the list.
  13. Require a password on wake up: set to NO
  14. Hard disk: turn off the hard disk: set to NEVER
  15. Wireless adapter settings:
  16. Sleep: set to NEVER
  17. Allow Hybrid sleep: set to NEVER
  18. Hibernate after: set to NEVER
  19. Allow wake timers: set to disable
  20. USB settings:
  21. USB selective suspend setting: set to NEVER
  22. Power Buttons and lid:
  23. Power button action: Setting: set to shut down
  24. Sleep Button Action: set to: do nothing
  25. PCI Express:
  26. Link State Power Management, Setting: OFF
  27. Processor Power Management: Minimum state (set to) 7%
  28.
  29. System Cooling Policy: setting: Active
  30. Maximum State (set to) 100%
  31. Display
  32. Turn off display after: setting: NEVER (turning off display automatically can cause freezing also)
  33. Turn off the monitor power manually, when you want it off. Don’t use the auto monitor turn off.
  34. Multimedia Settings:
  35. When Sharing Media: Setting: Prevent idling to sleep
  36. When Playing Video: Setting: Optimize Video
  37. Click APPLY
  38. Click OK
  39.
  40. Open the bios set up and make sure "cool and quiet" is OFF. (AMD)
  41. If there is a power saver or a "quiet mode" in the bios, shut it off...
  42. There may be a performance setting in the bios setup you have...make sure it's cranked up to max.
  43. in the bios, see that the allocation for video, if available, is maxed.
  44.
  45. Now open the hardware manager profiles...
  46. click start
  47. click computer
  48. click system properties
  49. click device manager
  50. double click on mice and other pointing devices
  51. right click on HID compliant mouse
  52. left click on properties
  53. click on the power management tab
  54. UN-check the box that says: "allow the computer to turn off this device to save power." (there is now NO check mark in this box)
  55. click OK
  56.
  57. Now repeat this procedure for all mice, monitors, keyboards, and ALL USB ports on the device manager list.
  58.
  59. You must open ALL the devices one at a time, as above, and turn off the power saver, for each device.
  60.
  61. NOW turn all the security back ON. NOW open your security antivirus. Make sure the antivirus is set to "gaming mode." Or "multimedia mode."
  62. This prevents the security updating from interrupting your game / multimedia priority.
  63. IF the security does not have "gaming mode" or "multimedia mode" get different security.
  64. IF you are using "free" security downloaded from the internet, get rid of it NOW.
  65. Use ONLY professional all in one security. DO NOT load multiple mismatched security programs, which conflict with each other.
  66. DO NOT load free tools into your system such as: "driver sweeper" or any of that "free" goofy stuff.
  67.
  68. Then re-test and let us know.
Ovaj post je ureden 1 puta. Posljednja izmjena 21.05.2018 20:44 od strane Avko. ↑  ↓
#12 23.05.2018 13:49
danas racunalo radilo neprekidno 6 sati bez restarta
#13 02.06.2018 00:14
I sta bi nadje li kvar?
Ja obicno prvo reinstalisem pa onda poslije gledam da li je do hardvera.
#14 02.06.2018 00:56
za sada radi bez da se resetira pa nebi dirao. neda mi se sve reinstalirati
#15 10.09.2018 11:27
evo opet se restartalo.
Kupio sam pastu za CPU. Skinuo hladnjak sa CPU, ocistio od stare paste isto tako ocistio i CPU od stare paste. Stavio novu pastu. Zatvorio i pricekao 2h.
Ukljucio racunalo i radi.
Mislim, radilo je i prije ali se svremena na vrijeme restartalo.
Sada mi je da pricekam pa cu vidjeti.
Ako se restarta onda cu reinstalirat ili kupiti isto takvo drugo. Vidjet cu.
#16 11.09.2018 08:44
restartirajne moze biti od svasta neispravno napajajne,graficka kart,ram memorija,maticna ploca,operativni sistem,eksterni ured i jos dosta drugi problema ...
#17 14.10.2018 13:46
evo opet.
Ocistio od prasine.
Otpojio sve uredaje i kabl 220
izvadio bateriju, pritisnuo power button i drzao 15 sekundi
promijenio mjesta memoriji
memorija:
freq CL RCD RP RAS RC V (<= sta znace ove oznake? freq je frekvencija a V je voltaza a ostalo?)
1.slot: 2gb 400mhz
400 5 5 5 18 23 1.8
266,7 4 4 4 12 16
200 3 3 3 9 12
2.slot: 512mb 333mhz
333 5 5 5 15 20 1.8
266,7 4 4 4 12 16
200 3 3 3 9 12
3.slot: 1gb 400mhz
400 5 5 5 18 23 1.8
266,7 4 4 4 12 16
200 3 3 3 9 12
4.slot:512mb 333mhz
333 5 5 5 15 20 1.8
266,7 4 4 4 12 16
200 3 3 3 9 12
jeli u redu imati takvu razlicitu memoriju u jednom racunalu?
#18 18.10.2018 21:40
U vecini slucajeva Memorija radi ali na frekvenciji koja je naj niza ali nije to bas tako.
Zna se i zakomplikovati pa da zablokira.
Neznam jesi li ovo rijesio pa zato i pisem ali trebao bi svakako probati samo sa jednom vrstom memorije.
#19 18.10.2018 22:22
za sada radi,
#20 19.10.2018 09:55
Pa jeli ovo pomoglo?
Sva vremena su GMT +01:00. Trenutno vrijeme: 5: 50 pm.
