iCentar » Forum » Racunari i oprema » Programirannje i baze podataka » Vb/Vbnet » svaki treći red iz datagrid-a
#1 26.02.2020 07:31
xl_kid Van mreze
Registrovan od:11.11.2008
Postovi:154
Predmet:svaki treći red iz datagrid-a
Da li postoji bolje rešenje za čitanje svakog trećeg reda iz datagrida? Kratak opis procedure, iz listview-a (podaci idu jedan posle drugog) prebacim podatke u datagrid1, podaci idu jedan ispod drugod (1 kolona više redova), iz njega prebacujem podatke u datagrid2 koji ima 3 kolone i veše redova (od_datuma, do_datuma, br_dana).
evo i koda:
Dim SourceDan As String = New Net.WebClient().DownloadString("https://www.nbs.rs/...11172934")
Dim recentSource As String = GetTagContents(SourceDan, "<table width=""100%"" border=""0"">", "</table>")(0)
Dim broj_dana_blokade As Integer
DataGridView1.ColumnCount = 2
DataGridView1.Columns(0).Name = "RB"
DataGridView1.Columns(0).Width = 40
DataGridView1.Columns(1).Name = "OD"
DataGridView1.Columns(1).Width = 100
DataGridView2.ColumnCount = 3
DataGridView2.Columns(0).Name = "OD"
DataGridView2.Columns(0).Width = 100
DataGridView2.Columns(1).Name = "DO"
DataGridView2.Columns(1).Width = 100
DataGridView2.Columns(2).Name = "DANI"
DataGridView2.Columns(2).Width = 100
For Each title As String In GetTagContents(recentSource, "<td>", "</td>")
Dim value As String = Trim(title.Replace(" ", ""))
Dim length As Integer = Trim(value.Replace(" ", "")).Length
If Not title.Contains("http:") Then
Dim lvi As New ListViewItem
lvi.Text = Trim(title.Replace(" ", "")) & " " & length
ListView1.Items.Add(lvi)
Dim j As Integer = 0
DataGridView1.Rows.Add(j + DataGridView1.RowCount, Trim(title.Replace(" ", "")))
Next
Dim broj = 1
For Each red As DataGridViewRow In DataGridView1.Rows
Dim rednibroj As Integer = DataGridView2.Rows.Count - 1
If broj = 1 Then
Dim length As Integer = Trim(red.Cells(1).Value.Replace(" ", "")).Length
If length > 3 Then
DataGridView2.Rows.Add(Trim(red.Cells(1).Value).Replace(" ", ""))
broj = 2
ElseIf length > 1 And length < 4 Then
broj_dana_blokade = Trim(DataGridView1.Rows(DataGridView1.Rows.Count - 1).Cells(1).Value.Replace(" ", ""))
TextBox1.Text = broj_dana_blokade.ToString
ElseIf broj = 2 Then
DataGridView2.Rows(rednibroj).Cells(1).Value = Trim(DataGridView1.Rows(rednibroj * 3 + 1).Cells(1).Value.Replace(" ", ""))
broj = 3
ElseIf broj = 3 Then
DataGridView2.Rows(rednibroj).Cells(2).Value = Trim(DataGridView1.Rows(rednibroj * 3 + 2).Cells(1).Value.Replace(" ", ""))
broj = 1
Next
#2 26.02.2020 10:26
Predmet:Re: svaki treći red iz datagrid-a
  1. For Each red As DataGridViewRow In DataGridView1.Rows
  2. Dim rednibroj As Integer = DataGridView2.Rows.Count - 1
  4. If broj = 1 Then
  6. Dim length As Integer = Trim(red.Cells(1).Value.Replace(" ", "")).Length
  7. If length > 3 Then
  8. DataGridView2.Rows.Add(Trim(red.Cells(1).Value).Replace(" ", ""))
  10. broj = 2
  12. ElseIf length > 1 And length < 4 Then
  13.
  14. broj_dana_blokade = Trim(DataGridView1.Rows(DataGridView1.Rows.Count - 1).Cells(1).Value.Replace(" ", ""))
  16. TextBox1.Text = broj_dana_blokade.ToString
  17. End If
  18.
  19. ElseIf broj = 2 Then
  20.
  21. DataGridView2.Rows(rednibroj).Cells(1).Value = Trim(DataGridView1.Rows(rednibroj * 3 + 1).Cells(1).Value.Replace(" ", ""))
  22.
  23. broj = 3
  24.
  25. ElseIf broj = 3 Then
  26. DataGridView2.Rows(rednibroj).Cells(2).Value = Trim(DataGridView1.Rows(rednibroj * 3 + 2).Cells(1).Value.Replace(" ", ""))
  27.
  28. broj = 1
  29. End If
  30.
  31. Next
Jeli to ova petlja?
Ne vidim ovdje kako povecavas variablu koja se zove broj.
Sa ovim broj bi mogao rijesiti da citas svaki treci ali ga moras povecavati za 3.
Prco reci jel ovo ta petlja i sto ce ti ovi if za broj.
#3 26.02.2020 10:43
xl_kid Van mreze
Postovi:154
Da, to je ta petlja. Jedino sam ovako uspeo da dobijem rešenje za svaki treći red. Probao sam i sa For petljom step 3 (kod dole) ali nikako nisam uspeo da dodelim vrednosti u koloni 2 i 3 jer mi index ide preko poslednjeg rednog broja. Evo i slike (gore levo, lista, dole levo moje rešenje, dole desno pokušaj sa for petljom i step 3
Dim rednibroj As Integer = DataGridView1.Rows.Count - 1
For i As Integer = 0 To rednibroj Step 3
od_datuma = DataGridView1.Rows(i).Cells(1).Value
' do_datuma = DataGridView1.Rows(i + 1).Cells(1).ToString
' broj_dana = DataGridView1.Rows(i + 2).Cells(1).Value
DataGridView3.Rows.Add(od_datuma)
Next
Preuzimanja:231
Velicina datoteke:45.54 KB
Velicina slike: 1423 x 767 Pikseli
#4 26.02.2020 13:19
  1. Dim x As Integer
  2. For Each red As DataGridViewRow In DataGridView1.Rows
  3. 'Dim rednibroj As Integer = DataGridView2.Rows.Count - 1
  4. x = x + 1
  5. If x Mod 3 = 0 Then
  6. MsgBox (oDataGridView1.Rows(i - 1).Cells(1).Value)
  7. End If
  9. Next
neznam koji red niti koju kolonu citas.
Nisi se izjasnio napr. re 1-4 itd ili red 3 6
u ov 3 grida imas razlicit broj kolona pa neznam koju kolonu citas
Ako se ne snadjes pisi ponovo
Sva vremena su GMT +01:00. Trenutno vrijeme: 2: 49 pm.
