iCentar » Forum » Racunari i oprema » Programirannje i baze podataka » Access » Access 2000
#1 03.11.2020 11:02
Bosanec Van mreze
Postovi:155
Predmet:Access 2000
Imam aplikaciju rađenu u accessu 2000 i koja je radila na windows xp bez problema
međutim kad se prebacila na windows 8.1 neće da radi
baza se pokreće preko access runtime msarn200
ona se dobro pokrene ali kada se počnu koristiti forme nemože
da dodjeljuje brojeve preko forme
da li treba neki servis pack ili nešto drugo
baza je zaključana preko workgroup
autori koji su radili bazu nema
#2 03.11.2020 11:37
Predmet:Re: Access 2000
Jeli mdb ili mde.
Jesil probao staviti na drugu particiju gdje nije win.
Probaj podici kao administrator.
#3 03.11.2020 11:55
Bosanec Van mreze
Postovi:155
mdb
pokrene se program i
i može da se uđe u program
ali neće da rade funkcije preko formi
nešto sam čito na netu
When you put in a parameter in the query line that comes from a variant data type, (such as a function which has no type or a field from a form, Forms!MyForm!MyCriteriaField, Access can misunderstand what datatype you are using. If you enter 1/1/97 in a field on a form, is that text, a date, or a mathematical function. The functions CInt, CLng, Cstr, CVDate, CDbl and all the rest, ensure that you are using the correct data type when there could be some confusion. In the full retail version, if Access is unsure as to what the type is, it gives you an error message, however, at times the runtime will just die a painful death (GPF). Making sure that all of your queries with parameters have been specifically cast using the CStr, etc. functions have eliminated many GPF's in runtimes for me.
proba sam i kao administrator
#4 03.11.2020 13:18
Ako smijes postaviti na forum postavi bit ce lakse ili bar mdw.
#5 03.11.2020 13:39
Bosanec Van mreze
Postovi:155
evo baze u prilogu
access runtime
i setup.ini fajl
evo na linku nemože da stane
https://drive.google.com/...sp=sharing
a evo mdw fajl
Informacije o tipu datoteke za:rar  MDW.rar
Preuzimanja:141
Velicina datoteke:309.55 KB
Ovaj post je ureden 2 puta. Posljednja izmjena 03.11.2020 13:47 od strane Bosanec. ↑  ↓
#6 03.11.2020 20:31
ima li jos koji mdw.
Ovi nemaju nikakvu sifru i mislim da nisu od ovoga.
#7 03.11.2020 21:17
Bosanec Van mreze
Postovi:155
nema to je što sam našo
a ove ja na ikoni od prečice upisano
C:\MSARN200.EXE C:\wips10.mdb /ini C:\WINDOWS\wips20.ini
#8 03.11.2020 22:50
Ova e access 2.0 mene taka mi izgleda
#9 03.11.2020 23:01
Da i ja mislim da je access 2 jedan dio.
Ima li ovo negdje da radi.
#10 03.11.2020 23:16
Bosanec Van mreze
Postovi:155
radi na xp
ali kad se instalacija prebaci na windows 8.1
nece
e sad što neće aj ga znaj
Sva vremena su GMT +02:00. Trenutno vrijeme: 9: 41 am.
