iCentar » Forum » Racunari i oprema » Programirannje i baze podataka » Access » sql upit u VBA-modu
#21 17.03.2011 17:43
Predmet:Re: sql upit u VBA-modu
Nakaci cijeli kod kad stignes.
Nema zaobilazenja ni izvlacenja.
Nastavljamo veceras drugu smjenu.
#22 17.03.2011 20:19
Zuko Van mreze
Registrovan od:13.09.2010
evo koda za usporishell
  1. Option Compare Database
  2. Option Explicit
  6.       Public Declare Function OpenProcess Lib "kernel32" (ByVal dwDesiredAccess As Long, ByVal bInheritHandle As Long, ByVal dwProcessId As Long) As Long
  7.       Public Declare Function WaitForSingleObject Lib "kernel32" (ByVal hHandle As Long, ByVal dwMilliseconds As Long) As Long
  8.       Public Declare Function CloseHandle Lib "kernel32" (ByVal hObject As Long) As Long
  10.       Public Const SYNCHRONIZE = &H100000
  12.       Public Const INFINITE = -1&
  13.
  14.       ' Usporava shel
  16.       ' to finish, hiding while we wait.
  17.
  18.       Public Sub UsporiShell(ByVal program_name As String, ByVal window_style As Integer)
  19.
  20.       Dim process_id As Long
  21.
  22.       Dim process_handle As Long
  23.      ' Start the program.
  24.      On Error GoTo ShellError
  25.      process_id = Shell(program_name, window_style)
  26.      On Error GoTo 0
  27.
  28.           ' Wait for the program to finish.
  29.
  30.          ' Get the process handle.
  31.
  32.          process_handle = OpenProcess(SYNCHRONIZE, 0, process_id)
  33.
  34.           If process_handle <> 0 Then
  35.
  36.               WaitForSingleObject process_handle, INFINITE
  37.
  38.               CloseHandle process_handle
  39.
  40.           End If
  41.
  42.           Exit Sub
  43.
  44. ShellError:
  45.
  46.           MsgBox "Error starting task " & _
  47.             " program_name & vbCrLf " & _
  48. " Err.Description , vbOKOnly Or vbExclamation, " & _
  49.                 "Error"
  50.         End Sub
a ovo je sa dugmeta na formi
  1. Private Sub Command7_Click()
  2. Dim g As Integer, d As String, Mjesec1 As String, firma As String, ime As String
  3. g = Year(Now())
  4. firma = DLookup("[Statisticki broj]", "tpreduzece", "Sifra_preduzeca = " & Forms!test!SifraFirme)
  5. d = Len(Forms!test!Mjesec1)
  6. If d = 1 Then
  7. Mjesec1 = "0" & Right(Str(Forms!test!Mjesec1), 1)
  8. Else
  9. Mjesec1 = Str(Forms!test!Mjesec1)
  10. End If
  11. ime = firma & "_" & Mjesec1 & g
  12. UsporiShell Db_Putanja & "\" & pkzip.exe & "  " & ime & ".zip " & Db_Putanja & "\" & ime & ".xml", vbHide
  13. 'UsporiShell putanjafajla & "\pkzip " & PutZipa & "\" & ImeFajla & ".zip " & PutZapisa, vbHide
  14. End Sub
ovdje sam pravio ime file-a, valjda je to ok
Pozdav,
Nedim
Ovaj post je ureden 1 puta. Posljednja izmjena 17.03.2011 20:21 od strane nzuko. ↑  ↓
#23 17.03.2011 21:15
Opsti oblik:
UsporiShell PutanjaappZipa & "\pkzip " & Util.PutZipaZipa & "\" & ImeFajla & ".zip " & PutZapisaFilea, vbHide
da pretpostavimo da ti je sve na jednom jestu i mdb i xml i pkzip exe.
Sto znaci da se sve nalazi na putanji Db_Putanja.
To je procedura koja nalazi putanju mdb.
U firma imas dimo imena filea
Cijelo ime:
Dim Ime filea
ImeFilea=firma & & mjesec1
Dim app_Path
app_Patth=Db_Putanja
Znaci sad u app_path imas putanju do dir gdje se sve nalazi.
i sad sve da sklopimo:
UsporiShell app_path & "pkzip " & app_path & ImeFajla & ".zip " & app_path & ImeFajla & ".XML" , vbHide
To bi u shelu izgledalo ovako ako se to napr nalazi na putanji C:\Mojabaza
C:\Mojabaza\pkzip C:\Mojabaza\pojeime.zip C:\Mojabaza\mojeime.xml
ovo trebas dobiti.
Provejri samo sta ti vraca procedura db_Putanja
jeli vraca:
C:\Mojabaza
ili
C:\Mojabaza\
ako vraca ovo drugo onda je ok.
A ako vraca prvo onda trebas jos dodati izmedju \
Ali prvo provjeri.
#24 17.03.2011 22:38
Zuko Van mreze
Db_putanja vraća ovo drugo, ali opet neće javlja istu gresku.
Evo zakaćio sam bazu pa ako mozes pogledati, usporishell se nalazi umodulu pakovanje
Pozdav,
Nedim
#25 17.03.2011 23:37
tako je kad na vrhu modula nemas ono
Option explicit
a lose kucas ko i ja mozda samo niansu bolje.
Dim app_Path
app_Patth = Db_Putanja
imefajla = firma & "_" & Mjesec1 & g
UsporiShell app_Path & "pk
app_path i
appPatth
ma dobro samo jedno t viska.
To je jedna stvar a druga je sto shell ne podrzava ime filea vece od 8 karaktera a ko je vece ime onda se pise napr. 1234567789.xml--->123456~1.xml
123456~1-->ukupno 8 karaktera
ako imas 2 filea koji naprimjer imaju imena:
1234567890.xml
1234567899.xml
onda ce se prvi zbvati
123346~1.xml
a drugi
123456~2.xml
#26 17.03.2011 23:48
Zuko Van mreze
hvala na pomoci, a ovo o kucanju si upravu kad sam radio na xml na validaciji sam imao najvise gresaka u kucanju pa mu fali nedi dio nije otvoren ili zatvoren.
puno hvala još jednom
Pozdav,
Nedim
#27 01.04.2011 13:12
edo_ze Van mreze
Registrovan od:23.12.2010
Postovi:6
@nzuko
u recordsetu ne smiješ davati ovakav uslov
WHERE (((TLD.Mjesec)=[forms]![test]![mjesec1]) AND ((Tradnik.Sifra_Preduzeca)=[forms]![test]![sifrafirme]))
za izvršnu SQL naredbu može ali za setovanje recordseta ide ovako:
WHERE (((TLD.Mjesec)=" & [forms]![test]![mjesec1] & ") AND ((Tradnik.Sifra_Preduzeca)=" & [forms]![test]![sifrafirme]& "))
ili ako su alfanumeričke vrijednosti:
WHERE (((TLD.Mjesec)='" & [forms]![test]![mjesec1] & "') ...
ima apostrof (') prije i li poslije navodnika
Sva vremena su GMT +02:00. Trenutno vrijeme: 5: 45 am.
