Prikazi cijelu temu 03.08.2018 13:07
Avko Na mrezi
Predmet:Re: kako koristiti vise kriterija u vba excel
hvala na trudu
evo u meduvremnu pronasao nesto na internetu malo sam preuredio i neke stvari izbacio :
koristimo ovako :
  1. sub proba()
  2.
  3. if Two_Con_Vlookup(Range(Cells(odReda, odKolone), Cells(doReda, doKolone)), traziA, traziB) = False Then
  4.                     'ako nije nasao
  5.                     msgbox "greska"
  6. end if
  7. end sub
  9. Function Two_Con_Vlookup(Table_Range As Range, Col1_Fnd, Col2_Fnd) As Boolean
  11.     Dim rCheck As Range
  12.     Dim bFound As Boolean
  13.     Dim lLoop As Long
  14.
  15.     On Error Resume Next
  16.
  17.     Set rCheck = Table_Range.Columns(1).Cells(1, 1)
  18.     With WorksheetFunction
  19.         For lLoop = 1 To .CountIf(Table_Range.Columns(1), Col1_Fnd)
  20.            Set rCheck = Table_Range.Columns(1).Find(Col1_Fnd, rCheck, xlValues, xlWhole, xlNext, xlRows, False)
  21.            If UCase(rCheck(1, 2)) = UCase(Col2_Fnd) Then
  22.                 bFound = True
  23.                 Exit For
  24.             End If
  25.         Next lLoop
  26.     End With
  27.
  28.     If bFound = True Then
  29.         Two_Con_Vlookup = True
  30.     Else
  31.         Two_Con_Vlookup = False
  32.     End If
  33.
  34. End Function
Ovaj post je ureden 1 puta. Posljednja izmjena 05.08.2018 07:21 od strane Avko.
