Prikazi cijelu temu 22.07.2011 13:13
Registrovan od:22.07.2011
Predmet:Re: Iran isključuje internet da "zaštiti" građane
Hi, if I'm understanfing you correctly all you would need to do is:
1. Unplug the cable going into your router from the cable modem.
2.) Then plug that cable directly into your computer. Your computer should now be connected by an ethernet cable to the modem.
3.) Power down your cable modem for at least a minute.
4.) Power the cable modem back on.
If your still unable to connect go to a command prompt and try running 'ipconfig /release' and then 'ipconfig /renew'.
This should get you going. If not post back and I can try and help further. Hope this helps!
