iCentar » Forum » Racunari i oprema » Programirannje i baze podataka » Access » Brisanje File_ova Iz Access-a
#1 11.07.2011 15:07
Zuko Van mreze
Registrovan od:13.09.2010
Predmet:Brisanje File_ova Iz Access-a
KAKO MOGI IZ ACCESS-a IZBRISATI NEKI FILE (KONKRETNO NEKI TXT FILE)
U HELP-u SAM NAŠAO KOMANDU ALI MI NIKAKO NEIDE SINTAKSA
object.Delete force
The Delete method syntax has these parts:
Part Description
object Required. Always the name of a File or Folder object.
force Optional. Boolean value that is True if files or folders with the read-only attribute set are to be deleted; False (default) if they are not.
KAKO GOD POSTAVIM SINTAKSU ON JAVI NEKU GREŠKU.
HVALA UNAPRIJED
Pozdav,
Nedim
#2 11.07.2011 15:45
Predmet:Re: Brisanje File_ova Iz Access-a
Naredba je kill.
Kill "C:\Mojfile.txt"
#3 11.07.2011 16:03
Zuko Van mreze
hvala ZXZ šta bih ja bez tebe kad upadnem u problem ti si uvjek tu da pomgneš
Pozdav,
Nedim
Sva vremena su GMT +02:00. Trenutno vrijeme: 4: 49 am.
