iCentar » Forum » Racunari i oprema » Programirannje i baze podataka » Access » Korisnicko ime iz koristan kod
#1 21.05.2013 22:09
Predmet:Korisnicko ime iz koristan kod
Pitanje od: @Miki2013
IsOpenedExclusive() As Boolean
IsOpenedExclusive = False
Dim rs As ADODB.Recordset
Set rs = con.OpenSchema(adSchemaProviderSpecific, , "{947bb102-5d43-11d1-bdbf-00c04fb92675}")
Dim strUsers As String
Dim intUsers As Integer
Do While Not rs.EOF
strUsers = strUsers & vbCrLf & Left(rs.Fields(1), Len(Trim(rs.Fields(1))) - 1) & "@" & Left(rs.Fields(0), Len(Trim(rs.Fields(0))) - 1)
intUsers = intUsers + 1
rs.MoveNext
Loop
rs.Close
Set rs = Nothing
If intUsers > 1 Then
MsgBox "Korisnici koji trenutno koriste bazu podataka:" & vbCrLf & strUsers, vbInformation
Exit Function
IsOpenedExclusive = True
End Function
Može li mi neko pojasniti kako ove podatke o korisnicima koji koriste bazu dobiti na formi?
Hvala unaprijed!
Ovaj post je ureden 1 puta. Posljednja izmjena 21.05.2013 22:10 od strane zxz. ↑  ↓
#2 21.05.2013 22:28
Predmet:Re: Korisnicko ime iz koristan kod
Ovu proceduru stavi u neki modul:
  1. Function IsOpenedExclusive() As String
  2.     IsOpenedExclusive = False
  3.     Dim rs As ADODB.Recordset
  4.     Set rs = con.OpenSchema(adSchemaProviderSpecific, , "{947bb102-5d43-11d1-bdbf-00c04fb92675}")
  6.     Dim strUsers As String
  7.     Dim intUsers As Integer
  8.     Do While Not rs.EOF
  9.         strUsers = strUsers & vbCrLf & Left(rs.Fields(1), Len(Trim(rs.Fields(1))) - 1) & "@" & Left(rs.Fields(0), Len(Trim(rs.Fields(0))) - 1)
  10.         intUsers = intUsers + 1
  11.         rs.MoveNext
  12.     Loop
  13.     rs.Close
  14.     Set rs = Nothing
  16.     If intUsers > 1 Then
  17.         IsOpenedExclusive = strUsers
  18.         Exit Function
  19.     End If
  20.     IsOpenedExclusive = True
  21. End Function
Sada napravi neku formu i na formu stavi tekst box kontrolu.
Na control source kontrole upisi:
=IsOpenedExclusive()
#3 21.05.2013 22:40
Miki2013 Van mreze
Registrovan od:03.05.2013
Postovi:38
Hvala na brzom odgovoru!
Zapne ovdje
#4 21.05.2013 23:26
Pa nema tu konekcije.
Mislio sam da si to vec napravio jer neznam odakle ces pristupati.
Evo ovdje ako je kod na current.
  2.     Dim cnn As New ADODB.Connection
  5.     'cnn.Open "Provider=Microsoft.Jet.OLEDB.4.0;" & _
  6.     "Data Source=C:\Program Files\Microsoft " & _
  7.     "Office\Office11\Samples\Northwind.mdb;"
  8.    Set cnn = CurrentProject.Connection
  9.     Set rs = cnn.OpenSchema(adSchemaProviderSpecific, , "{947bb102-5d43-11d1-bdbf-00c04fb92675}")
  10.     'Set rs = cnn.OpenSchema(adSchemaProviderSpecific _
  11.     , , JET_SCHEMA_USERROSTER)
  12.    Dim strUsers As String
  13.     Dim intUsers As Integer
  14.     Do While Not rs.EOF
  15.         strUsers = strUsers & vbCrLf & Left(rs.Fields(1), Len(Trim(rs.Fields(1))) - 1) & "@" & Left(rs.Fields(0), Len(Trim(rs.Fields(0))) - 1)
  16.         intUsers = intUsers + 1
  17.         rs.MoveNext
  18.     Loop
  19.     rs.Close
  20.     Set rs = Nothing
  21.     IsOpenedExclusive = strUsers
  22. End Function
#5 22.05.2013 20:56
Miki2013 Van mreze
Postovi:38
Nece prijatelju pa nece...
Probao sam danas na poslu preko servera ali sa onom prvom mi u unbound polju pise error a sa drugom na curent ne pokazuje nista pa ni error.
Mada, iskreno current mi i ne treba jer sam to odradio na drugaciji nacin a prvi postupak ko je logovan "kontrolisem" preko query-ja jer se u posebnoj tablici biljezi username, datum i vrijeme prijave kao i odjave.
Ukoliko je vrijeme odjave prazno ja tako znam da je korisnik jos uvijek logovan.
Ali eto volio bih da ako je to moguce i ostali korisnici vide ko je trenutno u bazi u slucaju da imaju record lock da mogu sacekati ili kontaktirati kolegu.
Nego, imam ja jedan mnogo veci problem o kojem sam pisao na http://www.elitesecurity.org/...ugog-mreza ali nazalost izgleda da mi niko nije mogao dati rjesenje.
Ukoliko ti imas kakav prijedlog bio bih veoma zahvalan.
Ovo ovdje mozes lock ili delete.
Hvala!
#6 22.05.2013 21:49
Ovo se mora dovesti do kraja samo treba biti strpljiv.
Trebas vidjeti u kojem redu pravi gresku.
Neznam znas li zaustaviti izvrsenje koda pa onda sa F8 korak po korak i citati rezultate.
Imam ja jos par verzija koda ali volio bih da mi kazes u kojem redu koda prijavljuje gresku pa ce biti lakse.
Ima jos nesto.
Kazes da koristis tabelu za logovanje.
Nadam se da u ovu tabelu pored imena korisnika ili id korisnika unosis i ime racunara posto sve mrezno radi.
Ako je to tako onda ti i iz ove tabele mozes naci ko je sve logovan i sa kojeg compa.
#7 22.05.2013 21:55
Sto se tice linka es. najbolje je da svoj pšroblem iznese u novoj temi.
#8 22.05.2013 22:15
Miki2013 Van mreze
Postovi:38
Ponovo hvala na brzom odgovoru.
sto se tice tabele logovanja u njoj imam ID, korisnicko ime, datum prijave, vrijeme prijave, datum odjave i vrijeme odjave. To sam uvezao da mi na "kljucnim" rekordima upise ko je sta unio ili promijenio (mislim konkretno na korisnicko ime) i to funkcionise super. a sto se tice naziva racunara sa kojeg je izvrsen unos ili izmjena za to koristim sljedeci kod u modulu
  1. Function ImeKompa()
  2. Dim strImeKompjutera As String
  4. strImeKompjutera = String(255, Chr(0))
  5. ImeRacunara strImeKompjutera, 255
  6. strImeKompjutera = left(strImeKompjutera, InStr(1, strImeKompjutera, Chr(0)) - 1)
  7. ImeKompa = strImeKompjutera
  8. End Function
a na formi sam napravio unbound polje i u njega unio naziv kolone "Komp" iz tabele "osnovna" gdje se i biljeze ti podaci, takodje uredno.
ali da ne duzim meni bi odgovarala i "jednostavna" kontrola recimo nesto kao broj korisnika koji su trenutno logovani
npr. Trenutno bazu koristi 3 lica
Iskreno, jos uvijek sam pocetnik tako da ne znam bas kako ide to sa pokretanjem koda ali uglavnom nakon svakog koda koji ubacim idem na kompajliranje i ako nesto nije uredu onda mi pogresan kod pozuti i strelicom misa preko tog ocitam vrijednosti
Konkretno u ovom tvom kodu zapne na liniji
Napominjem da radim u MS Accessu 2003 i da osim prvih 5 default-nih referenci nisam ukljucio ni jednu dodatnu
#9 22.05.2013 22:39
Probaj sa ovom procedurom, pa cemo onda nesto vise znati o tvojoj situaciji.
Na vrh nekog modula stavi ovo:
  1. Option Compare Database
  2. Option Explicit
  3. Global Const JET_SCHEMA_USERROSTER = _
  4.     "{947bb102-5d43-11d1-bdbf-00c04fb92675}"
a evo procedura i mozes je staviti umjesto one gore pa probaj.
  1. Function ReturnUserRoster()
  4. Dim Korisnici
  6. 'cnn.Open "Provider=Microsoft.Jet.OLEDB.4.0;" & _
  7.   "Data Source=C:\Program Files\Microsoft " & _
  8.     "Office\Office11\Samples\Northwind.mdb;"
  9. Set cnn = CurrentProject.Connection
  10. Set rs = cnn.OpenSchema(adSchemaProviderSpecific _
  12. Do While Not rs.EOF
  13. Korisnici = Korisnici & rs.GetString & vbCr
  14. Loop
  16. Set rs = Nothing
  17. Set cnn = Nothing
  18. End Function
Javi sta se desava.
Sva vremena su GMT +02:00. Trenutno vrijeme: 11: 27 pm.
