iCentar » Forum » Racunari i oprema » Programirannje i baze podataka » Access » konvert broja u slovo
#1 21.10.2016 09:16
nevsad Van mreze
Registrovan od:01.09.2010
Postovi:237
Predmet:konvert broja u slovo
imam funkciju koja broj 1824 pretvori u 1823 slovom
neznam gdje je greska
pozdrav
Function slovima(broj)
On Error Resume Next
If broj = 0 Then
slovima = "nula"
Exit Function
ReDim imebr(9)
imebr(1) = "jedan"
imebr(2) = "dva"
imebr(3) = "tri"
imebr(4) = "četiri"
imebr(5) = "pet"
imebr(6) = "šest"
imebr(7) = "sedam"
imebr(8) = "osam"
imebr(9) = "devet"
rez = ""
celi = Int(broj)
dec = ((broj - celi) * 100) Mod 100
cbr = Str(celi)
duzina = 16 - Len(cbr)
cbroj = String(duzina, "0") & right(cbr, Len(cbr) - 1)
i = 1
Do While i < 15
tric = Mid(cbroj, i, 3)
trojka = Val(tric)
If tric <> "000" Then
cs = Val(Mid(tric, 1, 1))
cd = Val(Mid(tric, 2, 1))
cj = Val(Mid(tric, 3, 1))
Select Case cs
Case 2
rez = rez & "dvije"
Case Is > 2
rez = rez & imebr(cs)
End Select
Select Case cs
Case 1
rez = rez & "stotinu"
Case 2, 3, 4
rez = rez & "stotine"
Case Is > 4
rez = rez & "stotina"
End Select
If cj = 0 Then sl1 = "" Else sl1 = imebr(cj)
Select Case cd
Case 4
rez = rez & "četr"
Case 6
rez = rez & "šes"
Case 5
rez = rez & "pe"
Case 9
rez = rez & "deve"
Case 2, 3, 7, 8
rez = rez & imebr(cd)
Case 1
sl1 = ""
Select Case cj
Case 0
rez = rez & "deset"
Case 1
rez = rez & "jeda"
Case 4
rez = rez & "četr"
Case Else
rez = rez & imebr(cj)
End Select
If cj > 0 Then rez = rez & "naest"
End Select
If cd > 1 Then rez = rez & "deset"
If (i = 4 Or i = 10) And cd <> 1 Then
If cj = 1 Then
sl1 = "jedna"
ElseIf cj = 2 Then
sl1 = "dvije"
rez = rez & sl1
Select Case i
Case 1
rez = rez & "bilion"
If cj > 1 Or cd = 1 Then rez = rez & "a"
Case 4
rez = rez & "milijard"
If ((trojka Mod 100) > 11 And _
(trojka Mod 100) < 19) Then
rez = rez & "i"
ElseIf cj = 1 Then
rez = rez & "a"
ElseIf cj > 4 Or cj = 0 Then
rez = rez & "i"
ElseIf cj > 1 Then
rez = rez & "e"
Case 7
rez = rez & "milion"
(trojka Mod 100) < 19) Or cj <> 1 Then
rez = rez & "a"
Case 10
rez = rez & "hiljad"
(trojka Mod 100) < 19) Or cj = 1 Then
rez = rez & "a"
ElseIf trojka = 1 Then
rez = rez & "u"
rez = rez & "a"
ElseIf cj > 1 Then
rez = rez & "e"
End Select
i = i + 3
Loop
slovima = rez & Str(dec) & "/100 KM"
End Function
#2 21.10.2016 09:32
Predmet:Re: konvert broja u slovo
Jel bas zelis gresku da nadjes u svom kodu ili...
Evo kod ima.
http://www.icentar.ba/...st&id=955
#3 21.10.2016 09:32
nevsad Van mreze
Postovi:237
funkcija je dobra
nije valjoa format broja
pozdrav
#4 26.10.2016 13:47
Recimo da želimo provjeriti kako rade ove funkcije, sa kojim kompajlerom to mozemo vidjeti?
Znaci zanimame neki mali kompjler kojim izvrsim te funkije, koji bi to bio?
ILi ako malo pojasnim, napisem u tom kompajleru str$=slovima(300) ili u zxz slucaju str$=BrSlovima(300)
ispod toga prepisem funkciju, a zatim kliknem RUN i pokaze mi se rezultat?
#5 26.10.2016 17:20
U Accesu kopiraš kod u neki modul i onda u Immediate Window (Nevsadov primjer) napišeš :
? slovima(12345)
Enter
i dobit ćeš rezultat procedure
Preuzimanja:257
Velicina datoteke:196.58 KB
Velicina slike: 1600 x 900 Pikseli
Ovaj post je ureden 1 puta. Posljednja izmjena 26.10.2016 17:21 od strane pmiroslav. ↑  ↓
#6 26.10.2016 23:22
znaci bez accesa neide?
tako sam i mislio. bilo bi prejednostavno da nije tako.
cini mi se da se radi o VBA jeziku, ali nisam siguran, pa bi to isto moglo raditi i u excelu na isti nacin kako si opisao. probat cu sutra pa javim.
hvala na odgovoru
#7 27.10.2016 00:21
Mozes ti ovu proceduru prepicati i u c++ i u javu ili neki dru programski jezik.
Ideja je bitna a naredbe nadjes na netu.
#8 27.10.2016 11:33
uzeo sam pmiroslavov metod, ali sam stavio u excel, jer mi muka od accesa.
Prvo sam stavio funkciju od nevsada, radi perfektno bez greske.
za broj 354 dobio sam odgovor: tristotinepedesetčetiri 0/100 KM, vrijeme 0,0000458158774563344
sada sam sa nekom dozom straha stavio funkciju od zxz-a, i naravno crne slutnje su se obistinile. Javilo mi gresku.
U redu 70, BrSlovima = Strb & ImenaB(DioTri, RodJ, I1) & BrSlovima
poziva se funkcija ImenaB(var1,var2,var3) koja ne postoji.
Sto je tada zxz radio , neznam. Vjerojatno su mu se motala po glavi imena pa je pozvao funkciju imena koje uopce nema.
Zamijenio sam ImenaB sa Cifre(var1,var2,var3) tako da 70-ti red izgleda ovako:
BrSlovima = Strb & Cifre(DioTri, RodJ, I1) & BrSlovima
i ...
ponovo greska, deklaracija var DioTri stavljen je kao String u 14 redu
Dim DioTri As String, deklaracijom kao Integer prolazi jer u redu 55 Str(1) = Cifre(Cifra, I2, I1) var Cifra je deklarirana kao Integer i to ...bla bla bla
znaci
14. Dim DioTri as Integer, da skratimo pricu
sada radi, pa pokrenimo sa BrSlovima(354), a rezultat je:
tristotinepedesetetirideset, cini mi se da daje ovu deset viska
pogledajmo BrSlovima(350)
tristotinepedesetdeset, to je u redu
znaci muce ga decimalno mjesto jedinica, ako je vece od 0 tj. ako je neki broj
u 135 redu zapocinje if uvijet
If PoRedu = 2 Then
If Cifra = 1 Then
Cifre = "naest"
Else
Cifre = Cifre & "deset"
tu nesto ne stima, po meni, ali neznam što. Nakon sto Strb ima ispravnu vrijednost uvijet ispituje Cifra, vrijednost je 5 te prvi uvjet if Cifra=1 nije zadovoljen ali zato ono Else se izvrši i doda "deset"
Neznam kako to riješiti, ali dok se problem ne riješi preporučio bi koristiti nevsadovu funkciju
vrijeme potrebno da se program izvrsi , iako zxz funkcija ne radi, je:
1234567890354
zxz0,00006397461129381550,0000363174649464781
nevsad0,00008045715276239210,0000508444509250694
Ovaj post je ureden 2 puta. Posljednja izmjena 27.10.2016 11:34 od strane Avko. ↑  ↓
#9 27.10.2016 16:41
Hehe dodao sam proceduru koja nedostaje.
Kada sam prekopirao sa starog foruma izgleda poslije nikome nije ni trebala.
Trebala je samo za kase dok su se radile.
#10 27.10.2016 17:21
Da napomenem moja procedura ne radi decimalne brojeve.
ja sam to radio drugacije.
Razdvojim broj na dva dijela cio i decimalni i 2 puta posalje proceduri tako da dobijem slovima i decimalni dio.
Sva vremena su GMT +02:00. Trenutno vrijeme: 8: 15 am.
