iCentar » Forum » Racunari i oprema » Programirannje i baze podataka » PHP » CRUD ne radi mi
#1 26.03.2020 01:18
Postovi:5,081
Predmet:CRUD ne radi mi
-- Table structure for table `products`
  1. CREATE TABLE IF NOT EXISTS `products` (
  2.   `id` int(11) NOT NULL AUTO_INCREMENT,
  3.   `name` varchar(128) NOT NULL,
  4.   `description` text NOT NULL,
  5.   `price` double NOT NULL,
  6.   `created` datetime NOT NULL,
  7.   `modified` timestamp NOT NULL DEFAULT CURRENT_TIMESTAMP ON UPDATE CURRENT_TIMESTAMP,
  8.   PRIMARY KEY (`id`)
  9. ) ENGINE=InnoDB  DEFAULT CHARSET=latin1 AUTO_INCREMENT=9 ;
-- Dumping data for table `products`
  1. INSERT INTO `products` (`id`, `name`, `description`, `price`, `created`, `modified`) VALUES
  2. (1, 'Basketball', 'A ball used in the NBA.', 49.99, '2015-08-02 12:04:03', '2015-08-06 06:59:18'),
  3. (3, 'Gatorade', 'This is a very good drink for athletes.', 1.99, '2015-08-02 12:14:29', '2015-08-06 06:59:18'),
  4. (4, 'Eye Glasses', 'It will make you read better.', 6, '2015-08-02 12:15:04', '2015-08-06 06:59:18'),
  5. (5, 'Trash Can', 'It will help you maintain cleanliness.', 3.95, '2015-08-02 12:16:08', '2015-08-06 06:59:18'),
  6. (6, 'Mouse', 'Very useful if you love your computer.', 11.35, '2015-08-02 12:17:58', '2015-08-06 06:59:18'),
  7. (7, 'Earphone', 'You need this one if you love music.', 7, '2015-08-02 12:18:21', '2015-08-06 06:59:18'),
  8. (8, 'Pillow', 'Sleeping well is important.', 8.99, '2015-08-02 12:18:56', '2015-08-06 06:59:18');
kod je zakacen u zip datoteku.
Javlja mi gresku u index.php lin 50
Connection error: could not find driver
Fatal error: Call to a member function prepare() on a non-object in C:\wamp\www\cms\index.php on line 50
ako netko zna molio bih lijepo odgovor. Malo proucavam primjere sa interneta.
Ovaj je sa LINK
Informacije o tipu datoteke za:zip  cruid.zip
Preuzimanja:217
Velicina datoteke:8.74 KB
#2 26.03.2020 02:17
Predmet:Re: CRUD ne radi mi
Ako si u config nastimao postavke onda je do PDO konekcije odnosno php_pdo_mysql.dll i
extension=php_pdo_sqlite.dll
Trebas otici u php/php.ini pa vidjeti jeli ukljucen dll:
extension=php_pdo_mysql.dll ---Ukljucen
;extension=php_pdo_mysql.dll---Iskljucen
Ako je ukljucen onda pogledaj http://localhost/dashboard/phpinfo.php
dali radi.
Ovaj post je ureden 1 puta. Posljednja izmjena 26.03.2020 10:39 od strane Avko. ↑  ↓
#3 26.03.2020 10:59
Postovi:5,081
da to radi, zahvaljujem.
Da objasnim kako ukljuciti php_pdo_mysql.dll za one koji neznaju.
Mozemo na dva nacina:
1. nacin
-Kliknemo na ikonu WAMP servera a koja se nalazi desno kod sata ili uz antivirusni program. Ta ikona govori da je pokrenut WAMP server.
-kada smo kliknuli na nju otvori se ovo:
odemo kursorom do php ekstenzije i otvorit ce se jos jedan izbornik, izgleda ovako
sada odemo do ekstenzije koju zelimo ukljuciti i kliknemo na nju. Pored nje pojavit ce se kursor i ona je sada ukljucena
2.nacin
wamp je instaliran na C: u root-u, a u folderu wamp imamo folder php.
Putanja do toga foldera je : C:\wamp\php
u folderu php pronademo file php.ini i editiramo ga nekim editorom (notepad++)
i sada pronademo extension=php_mysql.dll , ako nije ukljucena ispred se nalazi znak ; (tocka-zarez) a kada to maknemo i snimimo file onda ce biti ukljuceno.
Odmah ukljucite i extension=php_mysqli.dll
Sva vremena su GMT +02:00. Trenutno vrijeme: 11: 34 pm.
