iCentar » Forum » Racunari i oprema » Programirannje i baze podataka » MySQL » SQL upiti
#21 08.06.2020 12:34
Postovi:5,078
Predmet:Re: SQL upiti
Citiraj Gjoreski:
  1. SELECT *
  2. FROM tbl_calendar t1
  3. INNER JOIN tbl_citydepartmentoffice t2 ON t1.id_cityDepartmentOffice=t2.Id_cityDeparmentOffice
  4. INNER JOIN tbl_schedule t3 ON t2.id_department = t3.id_department
  5. INNER JOIN (SELECT A.DATE,B.id_office,B.id_department
  6.                   FROM tbl_schedule A
  7.                   INNER JOIN tbl_citydepartmentoffice B ON B.id_department=A.id_department
  8.                   WHERE A.id_employees=1001)
  9. tt ON tt.DATE=t3.DATE AND tt.id_department=t2.id_department AND tt.id_office=t2.id_office
Nažalost nije.
Ja sam malo isprobavao. Imam upit za sve employees i sve datume:
  1. SELECT r1.date, e1.id_employees, r1.id_department, s1.id_office, s1.startTime
  2. FROM tbl_schedule as r1
  3. INNER JOIN tbl_calendar AS k1 ON r1.date = k1.date
  4. INNER JOIN tbl_citydepartmentoffice AS s1 ON (k1.id_cityDepartmentOffice = s1.Id_cityDeparmentOffice AND r1.id_department = s1.id_department)
  5. INNER JOIN tbl_employees AS e1 ON r1.id_employees=e1.id_employees
  6. WHERE r1.date >= DATE('2020-06-01')
  7. ORDER BY r1.date ASC, r1.id_department ASC
  8. limit 0,100;
ako dodam u WHERE AND r1.id_employees=1001, pokaze mi samo za 1001 za sve datume a nevidim druge employeese. Isto tako ne vidim za 7.7. 1001 je FD to mi ne pokaze.
Mozda bi trebalo nesto sa IF THEN ELSE. Ako je id_department > 0 (IsNumeric) onda izvrši upit a ako nije onda neznam.
Zakompliciro sam previše. Ja sam razmisljao da uzmem za Vaska upit pa sa php stavim u array i onda idem od 1 do ubound(array) i pretrazujem za svaki dan po office za ostale. To mi jedino sada pada na pamet.
Ovaj post je ureden 1 puta. Posljednja izmjena 08.06.2020 12:35 od strane Avko. ↑  ↓
#22 08.06.2020 12:41
Postovi:5,078
  1. SELECT  r.name
  2. ,rv.Date
  3. ,rv.id_department
  4. ,CONCAT(rv.id_department,rv.Date) as kljuc
  5. FROM tbl_schedule rv
  6. INNER JOIN tbl_employees  as r ON rv.id_employees=r.id_employees
  7. WHERE  CONCAT(rv.id_department,rv.Date)
  8. IN (SELECT
  9. CONCAT(rv.id_department,rv.Date) as kljuc
  10. FROM tbl_schedule as rv WHERE id_employees=1001
  11. )
  12. AND
  13. rv.id_employees<>1001
pod uslovom da sam pogodio polje broj kancelarija.
U mom slucaju je to id_department
U ovome tvome upitu pokazo mi je sve zaposlenike koji su 7.6. imali Fraj dan s time da je izuzet Vasko 1001
Ovaj post je ureden 1 puta. Posljednja izmjena 08.06.2020 12:42 od strane Avko. ↑  ↓
#23 08.06.2020 12:51
Nije zakoplicirano ali nije dobro objanjeno.
Ja neznam engleski pa mi dodatno komlikuje.
Ja evo naprimjer neznam sa sigurnoscu u koju tabelu se upisuje rad.
Znaci treba opisati tabele i imena polja.
Ja se bar nemogu snaci.
Nije problem upita nego je problem znacenje polja.
Evo vidim odgovorio si mi da i dobio samo slobodne dane za te ljude.
To je pokazao iz razloga sto neznam koja je tabele za unos rada.
Jeli id_department broj kancelarije
Ovaj post je ureden 1 puta. Posljednja izmjena 08.06.2020 12:53 od strane zxz. ↑  ↓
#24 08.06.2020 13:43
Postovi:5,078
Raspored
id zaposlenik
id zgrada
datum
raspored nam govori u kojoj zgradi zaposlenik radi za odredeni datum.
grad
id grad
id kancelarija
id zgrada
u gradu imamo zgrade sa kancelarijama
Kalendar
datum
id grad
zaposlenik
id zaposlenik
ime
Kancelarija u zgradi ne radi uvijek isto. Subotom rade samo 2 zaposlenika u kancelariji u kojoj radnim danom rade 3 zaposlenika. Koliko ce smjena biti u nekoj kancelariji odreduje se preko tbl grad.
Zgradi se mijenja id prelaskom na subotu ili nedjelju pa tako kancelarija id 1 u id zgradi 10 radnim danom pocinje raditi od 5 dok nedjeljom pocinje raditi od 6.
#25 08.06.2020 15:47
PreuzmiIzvorni kôd (MySQL):
  1. SELECT  rv.id_employees
  2. ,r.name
  3. ,rv.Date
  4. ,rv.id_department
  5. ,o.id_office
  6. ,CONCAT(k.id_cityDepartmentOffice,rv.id_department) as kljuc
  7. FROM tbl_schedule as rv
  8. INNER JOIN tbl_employees  as r ON rv.id_employees=r.id_employees
  9. INNER JOIN tbl_calendar as k   ON k.date=rv.date
  10. INNER JOIN tbl_citydepartmentoffice as o   ON o.Id_cityDeparmentOffice=k.id_cityDepartmentOffice
  11. AND rv.id_department=o.id_department
  12. WHERE  o.id_office
  13. IN (SELECT o.id_office
  14. FROM tbl_schedule as rv
  15. INNER JOIN tbl_citydepartmentoffice as o   ON rv.id_department=o.id_department
  16. WHERE rv.id_employees=1001
  17. )
  18. rv.id_employees<>1001
Da budem iskren nisam dovoljno ni procitao.
Gore sam mislio da su prve dvije tabele 1 na 1.
Ovdje je problem kljuca za cetvrtu tabelu i ako je on
IdCityDepartmentOffice i
IdDepartment
onda bi ovo rjesenje trebalo biti dobro.
Nisam testirao.
#26 08.06.2020 19:36
Ja opet ne razumem nista sve radim napamet.
Mozemo li ovako:
Prvo uradi cu jedan sql koj ce nam iscitati sve zapise koje nam trebaju a kasnije cemo dodati uslov,evo SQL pogledaj jel ima on sve podatke koje nam trebaju ?
  1. SELECT r1.DATE, e1.id_employees, r1.id_department, s1.id_office, s1.startTime
  2. FROM tbl_schedule AS r1
  3. INNER JOIN tbl_calendar AS k1 ON r1.DATE = k1.DATE
  4. LEFT JOIN tbl_citydepartmentoffice AS s1 ON (k1.id_cityDepartmentOffice = s1.Id_cityDeparmentOffice AND r1.id_department = s1.id_department)
#27 09.06.2020 09:25
Postovi:5,078
  2. ,r.name
  3. ,rv.Date
  5. ,o.id_office
  17. )
IdDepartment
Nisam testirao.
id_employeesnameDateid_departmentid_officekljuc
1002Luka2020-06-013101106310
1003Marko2020-06-016101106610
1004Ivan2020-06-0120210620
1005Marta2020-06-013202106320
1006Smiljan2020-06-016202106620
1007Mitar2020-06-0130310630
1008Ahmed2020-06-013303106330
1009Aleksandar2020-06-016303106630
1002Luka2020-06-0210110610
1003Marko2020-06-023101106310
1004Ivan2020-06-026101106610
1005Marta2020-06-0220210620
1006Smiljan2020-06-023202106320
1007Mitar2020-06-026202106620
1008Ahmed2020-06-0230310630
1009Aleksandar2020-06-023303106330
1002Luka2020-06-036303106630
1003Marko2020-06-0310110610
1004Ivan2020-06-033101106310
1005Marta2020-06-036101106610
1006Smiljan2020-06-0320210620
1007Mitar2020-06-033202106320
1008Ahmed2020-06-036101106610
1009Aleksandar2020-06-0330310630
1002Luka2020-06-043303106330
1003Marko2020-06-046303106630
1004Ivan2020-06-0410110610
1005Marta2020-06-043101106310
1006Smiljan2020-06-046101106610
1007Mitar2020-06-0420210620
1008Ahmed2020-06-043202106320
1009Aleksandar2020-06-046202106620
1002Luka2020-06-0530310630
1003Marko2020-06-053303106330
1004Ivan2020-06-056303106630
1005Marta2020-06-0510110610
1006Smiljan2020-06-053101106310
1007Mitar2020-06-056101106610
1008Ahmed2020-06-0520210620
1009Aleksandar2020-06-053202106320
1006Smiljan2020-06-0610160610
1007Mitar2020-06-063101606310
1008Ahmed2020-06-066101606610
1009Aleksandar2020-06-0620260620
1007Mitar2020-06-0710170610
1008Ahmed2020-06-073101706310
1009Aleksandar2020-06-076101706610
Pokazuje sve osim Vasko 1001, nije ni točno.
ovako bi trebalo izgledati:
dateid_employeesnameid_departmentid_officestartTime
2020-06-011001Vasko10105:00:00
2020-06-011002Luka310111:00:00
2020-06-011003Marko610117:00:00
2020-06-021008Ahmed30306:00:00
2020-06-021009Aleksandar330312:00:00
2020-06-021001Vasko630318:00:00
2020-06-031009Aleksandar30306:00:00
2020-06-031001Vasko330312:00:00
2020-06-031002Luka630318:00:00
2020-06-041001Vasko30306:00:00
2020-06-041002Luka330312:00:00
2020-06-041003Marko630318:00:00
2020-06-051008Ahmed20205:30:00
2020-06-051009Aleksandar320211:30:00
2020-06-051001Vasko620217:30:00
2020-06-061009Aleksandar20209:00:00
2020-06-061001Vasko320215:00:00
2020-06-071001VaskoFD
#28 09.06.2020 09:28
Postovi:5,078
Citiraj Gjoreski:
Mozemo li ovako:
evo ištitalo je sve:
2020-06-021002Luka10105:00:00
2020-06-031003Marko10105:00:00
2020-06-041004Ivan10105:00:00
2020-06-051005Marta10105:00:00
2020-06-011004Ivan20205:30:00
2020-06-021005Marta20205:30:00
2020-06-031006Smiljan20205:30:00
2020-06-041007Mitar20205:30:00
2020-06-051002Luka30306:00:00
2020-06-011007Mitar30306:00:00
2020-06-021003Marko310111:00:00
2020-06-031004Ivan310111:00:00
2020-06-041005Marta310111:00:00
2020-06-051006Smiljan310111:00:00
2020-06-011005Marta320211:30:00
2020-06-021006Smiljan320211:30:00
2020-06-031007Mitar320211:30:00
2020-06-041008Ahmed320211:30:00
2020-06-051003Marko330312:00:00
2020-06-011008Ahmed330312:00:00
2020-06-021004Ivan610117:00:00
2020-06-031005Marta610117:00:00
2020-06-041006Smiljan610117:00:00
2020-06-051007Mitar610117:00:00
2020-06-031008Ahmed610117:00:00
2020-06-011006Smiljan620217:30:00
2020-06-021007Mitar620217:30:00
2020-06-041009Aleksandar620217:30:00
2020-06-051004Ivan630318:00:00
2020-06-011009Aleksandar630318:00:00
2020-06-061006Smiljan10105:00:00
2020-06-061007Mitar310111:00:00
2020-06-061008Ahmed610117:00:00
2020-06-071007Mitar10106:00:00
2020-06-071008Ahmed310112:00:00
2020-06-071009Aleksandar610118:00:00
2020-06-071001VaskoFDNULL    NULL
2020-06-061002LukaFDNULL    NULL
2020-06-071002LukaFDNULL    NULL
2020-06-061003MarkoFDNULL    NULL
2020-06-071003MarkoFDNULL    NULL
2020-06-061004IvanFDNULL    NULL
2020-06-071004IvanFDNULL    NULL
2020-06-061005MartaFDNULL    NULL
2020-06-071005MartaFDNULL    NULL
2020-06-071006SmiljanFDNULL    NULL
#29 09.06.2020 10:11
Ako je sve uredu ako imamo sva sta nam treba mozes li sad da nam kazes sta treba da se izdvoi iz ova tabela a sta ne treba biti tu pa da uradimo uslov
#30 09.06.2020 11:52
Postovi:5,078
2020-06-011001Vasko10105:00:00 TREBA
2020-06-051008Ahmed20205:30:00 TREBA
2020-06-041001Vasko30306:00:00 TREBA
2020-06-021008Ahmed30306:00:00 TREBA
2020-06-011002Luka310111:00:00 TREBA
2020-06-051009Aleksandar320211:30:00 TREBA
2020-06-031001Vasko330312:00:00 TREBA
2020-06-041002Luka330312:00:00 TREBA
2020-06-021009Aleksandar330312:00:00 TREBA
2020-06-011003Marko610117:00:00 TREBA
2020-06-051001Vasko620217:30:00 TREBA
2020-06-021001Vasko630318:00:00 TREBA
2020-06-041003Marko630318:00:00 TREBA
2020-06-061001Vasko320215:00:00 TREBA
2020-06-071001VaskoFDNULL NULL TREBA
dodao sam na tvoj upot ORDER BY r1.date ASC, s1.id_office ASC
Tako da mi sortira po datumu i office
rezultat:
plava treba
date Ascending 1id_employeesid_departmentid_officestartTime
2020-06-01100110105:00:00
2020-06-011002310111:00:00
2020-06-011003610117:00:00
2020-06-01100420205:30:00
2020-06-011005320211:30:00
2020-06-011006620217:30:00
2020-06-01100730306:00:00
2020-06-011008330312:00:00
2020-06-011009630318:00:00
2020-06-02100210105:00:00
2020-06-021003310111:00:00
2020-06-021004610117:00:00
2020-06-02100520205:30:00
2020-06-021006320211:30:00
2020-06-021007620217:30:00
2020-06-02100830306:00:00
2020-06-021009330312:00:00
2020-06-021001630318:00:00
2020-06-03100310105:00:00
2020-06-031004310111:00:00
2020-06-031005610117:00:00
2020-06-031008610117:00:00
2020-06-03100620205:30:00
2020-06-031007320211:30:00
2020-06-03100930306:00:00
2020-06-031001330312:00:00
2020-06-031002630318:00:00
2020-06-04100410105:00:00
2020-06-041005310111:00:00
2020-06-041006610117:00:00
2020-06-04100720205:30:00
2020-06-041008320211:30:00
2020-06-041009620217:30:00
2020-06-04100130306:00:00
2020-06-041002330312:00:00
2020-06-041003630318:00:00
2020-06-05100510105:00:00
2020-06-051006310111:00:00
2020-06-051007610117:00:00
2020-06-05100820205:30:00
2020-06-051009320211:30:00
2020-06-051001620217:30:00
2020-06-05100230306:00:00
2020-06-051003330312:00:00
2020-06-051004630318:00:00
2020-06-061002FDNULL    NULL
2020-06-061003FDNULL    NULL
2020-06-061004FDNULL    NULL
2020-06-061005FDNULL    NULL
2020-06-06100610105:00:00
2020-06-061007310111:00:00
2020-06-061008610117:00:00
2020-06-06100920209:00:00
2020-06-061001320215:00:00
2020-06-071001FDNULL    NULL
2020-06-071002FDNULL    NULL
2020-06-071003FDNULL    NULL
2020-06-071004FDNULL    NULL
2020-06-071005FDNULL    NULL
2020-06-071006FDNULL    NULL
2020-06-07100710106:00:00
2020-06-071008310112:00:00
2020-06-071009610118:00:00
znaci ovo treba ostati nakon upita:
Gjoreski , ti samo daj upit a ja cu isprobati i napisati rezultat. Isprobavat ćemo dok ne pogodimo.
Isto vrijedi i za zxz-a. Ti upit a ja rezultat
Ovaj post je ureden 3 puta. Posljednja izmjena 09.06.2020 12:01 od strane Avko. ↑  ↓
Stranice (6):1,2,3,4,5,6
Sva vremena su GMT +02:00. Trenutno vrijeme: 9: 39 am.
