iCentar » Forum » Racunari i oprema » Softver i operativni sistemi » Ms office » Nakon klika na excel file minimizirat i pokaze samo userform1
Postovi:5,081
Predmet:Nakon klika na excel file minimizirat i pokaze samo userform1
Postoji li kod kojim bi dvoklikom na excel file minimilizirali knjigu i ostavii samo prikazan userform1?
Predmet:Re:Nakon klika na excel file minimizirat i pokaze samo userform1
Mislis na prozor na vb editora u exelu
Postovi:5,081
ostane na ekranu samo userform pokrenut, evo na slikama min knjigu i min vb ekran
Preuzimanja:143
Velicina datoteke:234.34 KB
Velicina slike: 1642 x 884 Pikseli
Preuzimanja:153
Velicina datoteke:14.61 KB
Velicina slike: 1027 x 582 Pikseli
Ovaj kod stavi u neki modul. Otvori novi modul ako nemas.
  1. #If VBA7 Then
  2.     Private Declare PtrSafe Function ShowWindow Lib "user32" (ByVal hwnd As Long, ByVal nCmdShow As Long) As Long
  3.     Private Declare PtrSafe Function EnumWindows Lib "user32" (ByVal lpEnumFunc As Long, ByVal lParam As Long) As Long
  4.     Private Declare PtrSafe Function GetWindowText Lib "user32" Alias "GetWindowTextA" (ByVal hwnd As Long, ByVal lpString As String, ByVal nMaxCount As Long) As Long
  5.     Private Declare PtrSafe Function GetWindowThreadProcessId Lib "user32" (ByVal hwnd As Long, ByRef lpdwProcessId As Long) As Long
  6.     Private Declare PtrSafe Function IsWindowVisible Lib "user32" (ByVal hwnd As Long) As Long
  7. #Else
  8.     Private Declare Function ShowWindow Lib "user32" (ByVal hwnd As Long, ByVal nCmdShow As Long) As Long
  9.     Private Declare Function EnumWindows Lib "user32" (ByVal lpEnumFunc As Long, ByVal lParam As Long) As Long
  10.     Private Declare Function GetWindowText Lib "user32" Alias "GetWindowTextA" (ByVal hwnd As Long, ByVal lpString As String, ByVal nMaxCount As Long) As Long
  11.     Private Declare Function GetWindowThreadProcessId Lib "user32" (ByVal hwnd As Long, ByRef lpdwProcessId As Long) As Long
  12.     Private Declare Function IsWindowVisible Lib "user32" (ByVal hwnd As Long) As Long
  13. #End If
  15. Const SW_MINIMIZE = 6
  16.
  17.
  18. Private Function EnumWindowsProc(ByVal hwnd As Long, ByVal lParam As Long) As Long
  19.     Dim windowTitle As String
  20.     Dim processId As Long
  21.
  22.     If IsWindowVisible(hwnd) Then
  23.         windowTitle = String$(256, Chr$(0))
  24.         GetWindowText hwnd, windowTitle, Len(windowTitle)
  25.         windowTitle = Left$(windowTitle, InStr(windowTitle, Chr$(0)) - 1)
  26.         If Len(windowTitle) > 0 Then
  27.             br = InStr(1, windowTitle, "Microsoft Visual Basic for Applications")
  28.             If br > 0 Then
  29.             ShowWindow hwnd, SW_MINIMIZE
  30.             Exit Function
  31.             End If
  32.         End If
  33.     End If
  34.     EnumWindowsProc = 1
  35. End Function
  36.
  37. Function Minimiziraj()
  38.     EnumWindows AddressOf EnumWindowsProc, 0
  39. End Function
a ovo stavi u modul user form
  1. Private Sub UserForm_Initialize()
  2.    Minimiziraj
  3. End Sub
Postovi:5,081
hvala na trudu, ali ne radi.
Ono iza VBA7 se crveni.
Trazio po internetu pa naletio na neki excel primjer i tamo bilo ovo:
U ThisWorkbook staviti sljedece:
  1. Private Sub Workbook_Open()
  3.     Application.ScreenUpdating = False
  4.     Application.WindowState = xlMinimized
  6.     UserForm1.Show vbModeless
  8. End Sub
Hehe nece ti to pomoc.
Posto nisi napisao koju verziju op sisitema imas i koji ofis imas.
Napisi mi to pa cu probati ali to mora da radi ako si dobro ti uradio.
isprobano na win 10 64 bitni i office ver 14 32 bit.
Postovi:5,081
Excel 2007, WIN10, 64bit
A sto ako to ponesem sa sobom pa pokusam na Excel 2016, WIN11, 64bit dali ce i onda raditi?
trebalo bi da radi ako si dobro postavio.
Za kod trebas otvoriti modul.
i onda onaj kod na za poziv na modul od user forme.
Postovi:5,081
ono tvoje mi nije radilo, a ono sto sam nashao na internetu kod mene radi.
evo primjer kako ono sa interneta radi, jedina je mana sto onaj koji pokrece mora kliknuti na omoguci izvodenje jer nije folder u sigurnom folderu
Informacije o tipu datoteke za:zip  forma min textbox ddmmgggg.zip
Preuzimanja:135
Velicina datoteke:10.59 KB
Ovaj post je ureden 1 puta. Posljednja izmjena 30.12.2024 11:49 od strane Avko. ↑  ↓
Moje nije ni radilo ono sto ti hoces.
ja sam razumio da hoces kada pokrenes userform a ovo zatvaras pri otvaranju exela.
Sva vremena su GMT +02:00. Trenutno vrijeme: 11: 21 pm.
