iCentar » Forum » Racunari i oprema » Programirannje i baze podataka » Access » NSC fiskalni printer
#41 24.02.2017 11:37
biromega Van mreze
Registrovan od:10.12.2010
Postovi:189
Predmet:Re: NSC fiskalni printer
Probao sam na Windows 10, i ne javlja nikakav problem (cijeli opseg od 1 do 80000 i inače to traje dugo...)
Ja kod FPrintWIN koristim opciju: "Resident mode". Da li i vi isto koristite ili koristite polje: Default executable file.
#42 24.02.2017 11:58
Benny Van mreze
Registrovan od:21.02.2017
Postovi:4
Da i ja koristim "Resident mode". Nije bitno koliki je opseg. Mogu staviti i 20000 hiljada da se obrise on nekada padne ali nekada i prodje pa pokusavam da ustanovim zasto se to desava. Pokusao sam koristiti i komandu 107,1,______,_,__;3;ALL; ali i sa njom mogu obrisati manji broj artikala.
#43 24.02.2017 15:47
biromega Van mreze
Postovi:189
To je definitivno problem sa windows operativnim sistemom na tom računaru.
Cause
A driver has called IoCompleteRequest to ask that an IRP be completed, but the packet has already been completed.
Resolution
This is a tough bug to find because the simplest case -- a driver that attempted to complete its own packet twice -- is usually not the source of the problem. More likely, two separate drivers each believe that they own the packet, and each has attempted to complete it. The first request succeeds, and the second fails, resulting in this bug check.
Tracking down which drivers in the system caused the error is difficult, because the trail of the first driver has been covered by the second. However, the driver stack for the current request can be found by examining the device object fields in each of the stack locations.
#44 05.04.2017 08:58
Benny Van mreze
Postovi:4
Pozdrav,
fiskalni FP 500H mi se kontantno ispisuje linije. Ne mogu ga zaustaviti, jedini nacin da ugasim fiskalni. Upalim ponovo nastavi ispisivati liniju po liniju.
To izgleda ovako:
http://prntscr.com/esmet2
Kako da zaustavim ovaj ispis i nastavim normalan rad sa fiskalnom?
#45 05.04.2017 11:51
biromega Van mreze
Postovi:189
Ploca sigurno, memorija 50%
#46 05.04.2017 12:05
Što reko ciga kad ga sin pitao oćemo li na more ove godine
50% da hoćemo, a 100% da nećemo Wink
#47 05.04.2017 12:13
biromega Van mreze
Postovi:189
Nisam ovlašteni serviser, ali eto da "pomognem" nazovem ovlašteni servis i pitam. I dobijem takav odgovor, i samo sam taj odgovor: copy/paste. Koliko sam ja razmio: ploča se mora obavezno zamijeniti, a postoji i mogućnost da se mora mijenjati i fiskalna memorija. Valjda bi se ustanovilo nakon zamjene ploče.
Po mom mišljenju ako su obje komponente "otišle" bolje je uzeti novi printer (FP-700)
Ovaj post je ureden 1 puta. Posljednja izmjena 05.04.2017 12:18 od strane biromega. ↑  ↓
#48 05.04.2017 12:34
Mala šala, ništa zlonamerno Smiling
Iz tvojih postova se vidi da si dobro upućen u porblematiku
#49 06.04.2017 13:54
@biromega je ostao dugo na ovoj temi i hvala mu na tome.
Od pocetka je tu i zahvaljujuci najvise njemu niti jedno pitanje nije ostalo bez odgovora.
Stranice (5):1,2,3,4,5
Sva vremena su GMT +02:00. Trenutno vrijeme: 10: 48 am.
