iCentar » Forum » Racunari i oprema » Programirannje i baze podataka » Vb/Vbnet » Combobox as you type
#1 05.04.2019 12:36
xl_kid Van mreze
Registrovan od:11.11.2008
Postovi:154
Predmet:Combobox as you type
Pokušavam napraviti combobox da mi prikazuje samo vrednosti iz baze dok kucam.
Primer: u tabeli ima
ALGERIA
AUSTRALIA
AUSTRIA
ITALY
ST KITTS
ST LUCIA
UNITED STATES
ZAMBIA
ako u comboboxu unesem ST na mi prikaže sve gde ima taj kriterijum:
AUSTRALIA
AUSTRIA
ST KITTS
ST LUCIA
UNITED STATES
#2 05.04.2019 16:25
Predmet:Re: Combobox as you type
  1. Private Sub Form_Load()
  2.   Combo1.AllowAutoCorrect = False
  3.   Dim strSQL As String
  4.     strSQL = "SELECT * FROM tt WHERE Naziv Like '**'"
  6.   Me.Combo1.RowSource = strSQL
  8. End Sub
  10. Private Sub Combo1_Change()
  11. Dim strSQL As String
  12.     strSQL = "SELECT * FROM tt WHERE Naziv Like '*" & Me.Combo1.Text & "*'"
  13.
  14.   Me.Combo1.RowSource = strSQL
  15.   Me.Combo1.Dropdown
  16. End Sub
#3 08.04.2019 09:58
xl_kid Van mreze
Postovi:154
vb je u pitanju. Ovo je izgleda za access.
Me.Combo1.Dropdown
prijavljuje mi greške
#4 08.04.2019 11:28
ovo je access jel si trazio u access temama
za vb imamo vb tema
koja verzija vb koristis jeli vb6 ili vb.net
#5 08.04.2019 12:03
xl_kid Van mreze
Postovi:154
vb.net
visual studio 2017
#6 09.04.2019 10:54
Eve vidi dali ce raditi ova
  1.     Private Sub cboArtikli_TextChanged(ByVal sender As Object, ByVal e As System.EventArgs)
  2.         Dim rsArtikliBaraj = New ADODB.Recordset
  3.         Dim dtArtikliBaraj As New DataTable
  4.         Dim sqlBaraj As String
  5.         Dim i As Integer
  6.         sqlBaraj = "SELECT * FROM tblArtikli WHERE Artikal_Ime LIKE '%" & cboArtikli.Text & "%'"
  7.         'WHERE Description LIKE '%' + @SearchTerm + '%' AND Price <> '0.00'
  9.         rsArtikliBaraj.Open(sqlBaraj, cn, ADODB.CursorTypeEnum.adOpenStatic, ADODB.LockTypeEnum.adLockOptimistic)
  10.         dtArtikliBaraj = RecordSetToDataTable(rsArtikliBaraj)
  13.
  14.         '   Me.cboArtikli.DropDownStyle = ComboBoxStyle.DropDownList
  15.         '   Me.cboArtikli.AutoCompleteMode = AutoCompleteMode.None
  16.         '   Me.cboArtikli.AutoCompleteSource = AutoCompleteSource.None
  17.
  18.         '        Me.cboArtikli.AllowDrop = True
  19.         Me.cboArtikli.DataSource = dtArtikliBaraj
  20.         '        Me.cboArtikli.DisplayMember = "Artikal_Ime"
  21.         '        Me.cboArtikli.ValueMember = "ID_Artikal"
  22.         Me.cboArtikli.Refresh()
  23.         Me.cboArtikli.DroppedDown = True
  24.         'Me.cboArtikli.DataBindings.Add("SelectedValue", dtArtikliBaraj, "Ed_Mera")
  25.
  26.     End Sub
#7 09.04.2019 11:58
xl_kid Van mreze
Postovi:154
Moja baza je MSSQL. Probao sam sa izmenama ali mi dozvoljava samo jedno slovo da upišem. Ali rezultata je dobar
Private Sub nazivdm_combo_TextChanged(sender As Object, e As EventArgs) Handles nazivdm_combo.TextChanged
Dim strconn As String = "Data Source=10.10.60.83;Initial Catalog=INIT_DB;User ID=###;password=###"
Dim conn As New SqlConnection(strconn)
Dim cmd As New SqlCommand("SELECT Naziv FROM Kupci WHERE Naziv LIKE '%" & nazivdm_combo.Text & "%'", conn)
Dim da As New SqlDataAdapter(cmd)
Dim ds As New DataSet
da.Fill(ds, "List")
Dim col As New AutoCompleteStringCollection ' From which our names will come
Dim i As Integer
For i = 0 To ds.Tables(0).Rows.Count - 1
col.Add(ds.Tables(0).Rows(i)(0).ToString())
Next
'Dim rsArtikliBaraj = New ADODB.Recordset
'Dim dtArtikliBaraj As New DataTable
'Dim sqlBaraj As String
'Dim i As Integer
'sqlBaraj = "SELECT * FROM Kupci WHERE Naziv LIKE '%" & nazivdm_combo.Text & "%'"
'rsArtikliBaraj.Open(sqlBaraj, cn, ADODB.CursorTypeEnum.adOpenStatic, ADODB.LockTypeEnum.adLockOptimistic)
'dtArtikliBaraj = RecordSetToDataTable(rsArtikliBaraj)
'txtFirstName.Text = ds.Tables("AddressBook").Rows(0).Item(1)
'Me.nazivdm_combo.DropDownStyle = ComboBoxStyle.DropDownList
'Me.nazivdm_combo.AutoCompleteMode = AutoCompleteMode.None
'Me.nazivdm_combo.AutoCompleteSource = AutoCompleteSource.None
Me.nazivdm_combo.DataSource = col
' Me.nazivdm_combo.DisplayMember = "Naziv"
' Me.nazivdm_combo.ValueMember = "ID"
'Me.nazivdm_combo.Refresh()
'Me.nazivdm_combo.DroppedDown = True
Sigurno sam negde pogrešio
#8 10.04.2019 22:26
Nisi nigde pogresio problem je combo box
On je ogranicen sa mogucnosti pa resejne bi bilo megalomansko.
Jedan nacin da resis ovo je da uzmes neki drugi combo Box na primer DBCombo ili TDBCombo ili
ako neces koristiti neki drugi como box stavis text box i list box u kombinacija.
Razmisli pa javi
#9 10.04.2019 23:15
Neznam jeli ovo to sto trazis ali probaj p vidi.
U AutoCompleteMode odaberi SuggestAppend
a u
AutoCompleteSource ListItems
#10 11.04.2019 09:59
xl_kid Van mreze
Postovi:154
@zxz neće. hoću da kada unesem recimo "st" dobijem u listi AUSTRALIA, AUSTRIA, ST KITTS a kada nsatavim i dodam r (da bude str) lista tj odabir bude AUSTRALIA, AUSTRIA.
@Gjoreski pokušaću textbox. ako imaš neki primer bio bih i zahvalan
Sva vremena su GMT +01:00. Trenutno vrijeme: 12: 51 am.
